Dilemma- Radix fuel question
TOWN CRIER
OK, I have a 2006 truck with a return-less fuel set up. I also have (on the way) a 112 kit set up for an 2003 with return style fuel set up. Should I swap the fuel rail on the manifold and stick with a return-less set up, or route another line, swap out the pump and go with a return style system? I know the return type set up is a good bit more work, but isn't it a superior set up? Also, is the PCM different in how it reads fuel? Need as much input as y'all feel like giving.... Thanks.
The return type setup has a vacuum regulator on the rail. The desired outcome of that regulator is to have consistent fuel delivery under vacuum, atmospheric pressure, or boost. Under vacuum (less than atmospheric pressure) there is less resistance for fuel to flow against, so the regulator reduces pressure on the rail to compensate. It acts opposite while under boost, where the regulator increases fuel pressure to compensate for the added resistance of a pressurized manifold. That means more fuel for boosted users.
The returnless doesn't adjust for vacuum or boost. Its supposed to maintain steady pressure under all conditions. But many times, under high demand situations, like boosted vehicles, the pressure starts dropping. That means less fuel for boosted users.
Does that help?
Does that help?
To be safe Call Magnuson.
That lil red truck is going to be fun. When you get it be sure to dyno it before running it hard unless you have a wide band read out in the cab.
TOWN CRIER
TOWN CRIER
If you're going to just stay with around a 3.2-3.4 pulley making around 6-8 psi boost, I would just keep your truck returnless. Put a good Walbro in the tank, get a set of rails for the returnless set-up, and make sure your tune is set up for the returnless system. Switching the truck to return style is a lot more work than everyone thinks. In my opinion, not worth the effort unless you eventually are going for big power.
