Dash logic
Old Mar 12, 2018 | 07:46 PM
Adam Barber's Avatar
Default Dash logic
Hi I have a dash logic that I can view most of my factory sensors threw my driver information center. That being said I have my truck supercharged and I am trying to read boost. I read my intake manifold pressure but it does not go past 3lbs I assume I am making more than this is there something I can do to have a more accurate reading? Thanks
Old Mar 12, 2018 | 08:00 PM
kbracing96's Avatar
No, You're stock MAP sensor is only 1 bar and can only see up to 3lbs of boost. You would have to install a 2/3 bar MAP sensor and have it retuned for it for it to be able to show anymore boost.
Old Mar 12, 2018 | 08:32 PM
crashmymax's Avatar
Like KB siad put a 2/3 bar on and get it tuned. I use dash logic and it will work fine after you change the map.
Old Mar 13, 2018 | 07:58 AM
What map sensor did you go with and what all do you watch with your dashlogic
Old Mar 13, 2018 | 10:13 AM
crashmymax's Avatar
I use a corvette map can't remember what year. I have not done much with my dash logic. I know it can do a lot more stuff. I have page 1 boost, AFR, transmission temp
Old Mar 13, 2018 | 10:46 AM
ToBiN!'s Avatar
you can find GM 2 Bar MAPs on Amazon. Go with OEM. don't get the cheap knockoff. It could cost you more than just a couple bucks in the end.
So.cal Wrk Sled
Feb 25, 2016 11:56 PM
FS560
Sep 15, 2005 03:31 PM
jeffsy2kta
Jan 4, 2005 08:40 PM
Todd@AZPowerAndSound
Oct 20, 2004 05:54 PM
