Dash logic
Old Oct 30, 2014 | 01:21 PM
  #21
So.cal Wrk Sled's Avatar
Originally Posted by TIM Z
Sounds cool , but does it or can it read actual fuel psi also ?
Yes it does. Some applications will need fluid sensor installed.(PLX module) On another note I now found out if you delete MAF, in which I did I loose some of the functions. So far instant and av MPG and HP I don't have. I just finally installed PLX module for WB, works great! Not to mention you can set alarms for everything and customize how you want your display to read. Its a cool product!
Old Jan 10, 2016 | 12:12 PM
  #22
crashmymax's Avatar
Has dash logic been working good for you? Did you need to buy anything else for it to work as wideband gauge? Does it get in the way of your legs while driving?
Old Jan 11, 2016 | 04:26 PM
  #23
You need to get PLX devices DM-6 wide band box that's it. it doesn't get in way at all, you can always move it under dash if needed. I like not having gages in trk and unit is able to set chimes or alerts on everything as well.
I have boost/ trans temp and fuel pres all in dash display at all times. and 7 other pages of engine info. its bad ***..
Old Jan 11, 2016 | 07:18 PM
  #24
crashmymax's Avatar
Great thanks!
Old Feb 15, 2016 | 12:37 PM
  #25
crashmymax's Avatar
how did you connect you dash logic and PLX device? Not sure how they should be wired together. I was kind of thinking the 2 devices communicated wirelessly. I was wrong. any help on wiring this thing up would be great thanks.
Old Feb 16, 2016 | 03:03 PM
  #26
There is only one green wire from plx box to front of dash logic box. that's it.
Old Feb 16, 2016 | 09:11 PM
  #27
RS/SS 4.8's Avatar
10 Second Truck Club
Any pics of it working on the dash?
Old Feb 16, 2016 | 09:37 PM
  #28
crashmymax's Avatar
ok thanks.
Ill post some of mine when i get it working fully.
Old Feb 17, 2016 | 05:10 PM
  #29
Ill post some when I get home tonight.
Old Feb 20, 2016 | 03:23 PM
  #30
crashmymax's Avatar
here is a video just got it working I have only messed with page 1 the others are just factory set. I have one to many characters on the first line that's why you don't see the full AFR
