cutting out under boost
Old Aug 10, 2014 | 03:01 PM
  #21
oakley6575's Avatar
Originally Posted by BlackGMC
Do you have a Fuel Pressure gauge?
He said earlier in the thread it is 60 psi at idle and stays at 58 psi under boost
Old Aug 10, 2014 | 06:27 PM
  #22
tim wellington's Avatar
Default tune
you running m.a.f or speed density. when I was running my maf mine would do same thing went through two of them ,before I went speed density
Old Aug 10, 2014 | 06:42 PM
  #23
LS1TRUCKGUY's Avatar
Speed density. MAF is only used for iat sensor. Corey, i have a wideband, fuel pressure and boost/vac gauge. What size oetiker clamps do i need for oe style fuel tubing?and how long does the tubing need to be? Its been a while since i had a fuel bucket assembly out of the tank. Im going to go ahead and swap out this 340 for a walbro
Old Aug 20, 2014 | 04:26 AM
  #24
Update: i discovered a plug with with broken porcelain under the plug wire. I ended up with a set of BR6EF's in it gapped at 26 thou. I had charlie do some logs, and a little tweaking and she runs good again. Bonehead oversight on my part
Old Aug 20, 2014 | 07:46 AM
  #25
Default plugs
had same problem years ago on my nitrous car. every since then i check mine with magnifying glass .some times right the store be fore i buy them. GLAD YOU GOT IT RIGHT
Old Aug 20, 2014 | 09:13 AM
  #26
I dont get why this thing doesnt like a wider plug gap. I put these plugs in gapped at 30thousandths and it still had a miss. It got better at 28 thousandths and went completely away at 26.
Old Aug 20, 2014 | 09:46 AM
  #27
Atomic's Avatar
I have a gauge for that
I have mine gapped at 20 thou if it makes you feel better.
Old Aug 20, 2014 | 02:17 PM
  #28
I know 26 isnt that tight, but 12-14psi shouldnt be blowing out spark at that gap. I understand tighter gaps as boost goes up to prevent this.
Old Aug 20, 2014 | 02:18 PM
  #29
I had tr6's gapped at 30 thou in the truck since last october when i put the motor in and had zero issues. Now i need to tighten up the gap?? Nothing else has changed.
Old Aug 21, 2014 | 07:08 AM
  #30
Atomic's Avatar
Copper plugs wear out faster, especially in FI setups...
