cutting out in boost around 5K and up,
hey guys just got the truck dyno tuned. im having a badddd misfire up top when im in boost and its graduale got worse. the truck will just fall on its face and pop and basically rev but go no were..
my mods are a 5.3 67k miles. isky triple 12 cam, kb racing 72mm FMI kit. stage 3 4l60e from performabuilt. 3200 stall. 3.73 gears. im running meth, and only 9lbs of boost.
to start out the truck did throw a p0300 code.. my tuner said it was down low from the TQ so u just to that code off. we bought a brand new MAF sensor when we were on the dyno. now all of a sudden it is throwing a p0101 code: MAF range and voltage etc.. im running NGK TR6 plugs.. was gapped at .035. so i changed the plugs cuz i thought i was gettting spark blow out, put new TR6s in and gapped too .28 no luck!!! i also have msd wires, volts are good on them i checked em. also i know im going to get realitivly bad gas milege. but im getting HORRIABLE gas milage. i burned nearly a 1/4 tank yesterday cruising not in boost, and i only went 25-30 miles...
any input would be greatly appreciated!! i need to figure this out!
also forgot to mention, i have five-0-motorsports 60lb injectors, and a aeromotive 340 steath intank pump with a casper hotwire kit.. it is returnless style. i also have no problems with Fuel pressure. its about 63 all the time.
how do you check your coil packs?
and basically.. he said he tuned numerous corvettes that had this code after a verter install, and said the verter was causing it down low.
but when the truck is realitivly cold it shakes at idle like its got solid motor mounts.. lol
Possibly valve float? What springs do you have? I'm having the same problem with my truck falling on its face at 5k, minus the missing though. I ended up going with dual springs for the added security from dropping a valve and also attempt to fix the problem. Mine ended up being a fuel problem.
Usually with valve float and boost it doesn't start missing, it just stops making power. That's if it doesn't tear your valvetrain up first. You can check coil packs by measuring coil resistance. Sometimes though, certain coil packs just aren't up to the task. I have seen this problem many times, and it is popping up more often now with more and more people getting the "LS boost bug". I might have to do a writeup on checking coils...
