CR List: Post up your FI CR
Old Aug 9, 2010 | 03:44 PM
  #51
Spoolin's Avatar
GFYS and STFU
Oops, I forgot we need to add horsepower on the graph too...
Old Aug 9, 2010 | 03:50 PM
  #52
Atomic's Avatar
I have a gauge for that
Originally Posted by Spoolin
I think having the CID the way you have it skews the graph a bit. I think if one color could be used for the 290-350 CID engines, one for the 350-400 CID engines and a third for the 400+ CID engines would make things a bit clearer.
Well now you say something
HP is more difficult, especially when guys give a range of boost values. For that data I just averaged the range they gave, but hp is different at each boost level, I guess I could average the two values as well....
Old Aug 9, 2010 | 05:11 PM
  #53
brent1976's Avatar
11 Second Club
Just put both values, low boost/high boost.
Old Oct 12, 2011 | 10:54 AM
  #54
smokeshow's Avatar
Mod with training wheels
Bump for this, good info here.
Compression Ratio: 9.6
Motor/Displacement: 364
Amount of Boost: 16psi
Type of FI: front mount S475
Meth Yes or No: yes
Max Power: 685 by trap speed calculator. dynoed 635/895 through a choked up turbine housing
Verdict: LOT of under the curve power makes it very fun on the street, anything under 70mph is a tire killer
Old Oct 12, 2011 | 01:34 PM
  #55
swift700's Avatar
Compression ratio: 9.92:1
Motor/Displacement: 383
Amount of boost: 8.5 lbs
Type of FI: TVS 1900 overdriven
Meth yes/no: no
Max power: 491 rwhp
Verdict: Lots of power and torque. Runs a 12.6 @110 at 4000ft DA through a single 3" exhaust. Working on a better exhaust setup- peaks at just 5800 rpm.
Old Oct 12, 2011 | 03:28 PM
  #56
idahoblkss's Avatar
Compression ratio: 10.0-1 stock lq9
Motor/Displacement: 366
Amount of boost: 12-13 lbs
Type of FI: D1 PROCHARGER
Meth yes/no: no
Max power: 640 ACCORDING TO THE CALCULATOR
Verdict: 11.8@116
Old Oct 12, 2011 | 04:09 PM
  #57
AKlowriderZ71's Avatar
11 Second Hall Moniter
Compression ratio: 9.45:1
Motor/Displacement: 325
Amount of boost: 9 lbs
Type of FI: MP112 with 2.8 pulley
Meth yes/no: no
Max power: 580-600 rwhp (depends on the online calculator you plug the numbers into).
Verdict: Very fun daily that can shred tires whenever you ask it to. Or, hit the 4x4 button, and smoke almost everything else on the road. 0-60 in 3.6 seconds.
RustyD
May 23, 2016 07:04 PM
dsbodley
Nov 14, 2015 09:46 PM
Wrecker 426
Sep 29, 2015 11:00 PM
