Cooling down Engine turbo
#21
You can get better fans. I got some 2500 suburban fans off rock auto I think it was these ones. They pull so much air it will suck a t shirt against the grill when they are on.
#22
The best way to tell if it's fans or the core. If the core isn't clogged with grass/bugs etc in front.
And it won't cool down or keep cool at 55mph hwy speed. It's a core/ flow issue.
If it stays cool at speed and not at idle / low speed stop and go traffic.
It's fans not moving enough air.
Adding a turbo should not make your cooling system change drastically.
Sure at max power you want more/better cooling but just cruising turbo is not doing much.
Im picking up HP Tuners, to try and look over somethings on my tune, just in case something else is going on that i am not seeing.
