Cool Air
Old Apr 7, 2008 | 06:48 PM
dan96z71's Avatar
I have a truck with a trick kit already on it if you want it. I won't even pick on your pink pig if you buy mine!
Old Apr 7, 2008 | 06:52 PM
TrickTurbo's Avatar
Truck Sponsor
Old Apr 7, 2008 | 07:02 PM
TURBHOE's Avatar
i want a nnbs. maybe even one of those small d-max 1500's they are suppose to be making.
and all i got to say is only real men can sport pink and a bowtie.
Old Apr 7, 2008 | 08:22 PM
454SuperSport's Avatar
looks good, have you thought about putting a small efan behind the intercooler? is that air filter the metal mesh kind? had terrible heat-soak with one of those on a grand national.
Old Apr 8, 2008 | 08:00 AM
TURBHOE's Avatar
thought about the efan but don't have the money right now. well, its like a generic k&n filter. i'm going to get an aem dry flow some day.
Old Apr 8, 2008 | 04:55 PM
I know the feeling, the hoe takes all my money too, lol
Old Apr 8, 2008 | 06:12 PM
SpoolinChevy's Avatar
I was going to do something similar on my valence, but i went ahead and ditched the liscense plate and made a bigger hole. But i didnt have a pink plate to be proud of either.
Old Apr 8, 2008 | 06:19 PM
WJ MARK's Avatar
I got w 10" e-fans off ebay for 25 bucks each. I should have them mounted later this week. Just waiting on someone to send me a harness
Old Apr 8, 2008 | 06:27 PM
TURBHOE's Avatar
i would have made the hole wider but then it would have pointed out that my IC is a bit off set. i had to mount it a touch to the passenger side due to the steering lines i think it was. and i had to mount it lower than i wanted due to the trans cooler lines. i need a lower valance piece off the newer 05 and newer tahoes that have the e-fans then it would cover up the bottom of the IC.
Old Apr 8, 2008 | 06:36 PM
i would have made the hole wider but then it would have pointed out that my IC is a bit off set. i had to mount it a touch to the left due to the steering lines i think it was. and i had to mount it lower than i wanted due to the trans cooler lines. i need a lower valance piece off the newer 05 and newer tahoes that have the e-fans then it would cover up the bottom of the IC.
oh ok. It sill looks good though.
