View Poll Results: Which service would you like? (multiple answer poll)
Billet 90mm LS2 flange only, I will have it welded on
30.00%
Send my J-tube in, have the flange completed, and shipped back to me
62.50%
I will modify my own J-Tube
12.50%
Multiple Choice Poll. Voters: 40. You may not vote on this poll
Conversion Flange for Radix J-Tube/90mm LS2 Throttle Body ....PICS inside!!
Old Mar 31, 2006 | 08:58 AM
  #141
Richard@WCCH's Avatar
FormerVendor
Thanks Grippy. So to clarify, the UMI throttle body uses the same flange as the 90mm Corvette. If a guy wants to put a cable unit on his truck, he can buy one of our adapted tubes and bolt on the UMI throttle body.
Do I have this right?
Richard
Old Mar 31, 2006 | 09:11 AM
  #142
UMI has the same bolt pattern as a 90mm LS2 throttlebody.I have one on my truck.
Old Mar 31, 2006 | 11:31 AM
  #143
moregrip's Avatar
what a rush!
Richard
That's affirmative
Old Mar 31, 2006 | 11:50 AM
  #144
BlownChevy's Avatar
blownerator
25 Year Member
Richard
thats a big fo sheezy
I thought it might have provisions for both the 3 bolt and 4 bolt, but I was wrong....sorry Richard.
Old Mar 31, 2006 | 03:42 PM
  #145
F8L Z71's Avatar
Ok this is lame. How do you get the TB bolts out of the J-Tube? Are they simply screwed in and if so is there a socket with a reverse Torqx that I can get to take it off or what? I ask because I am trying to install my NW TB today and it comes with its own bolt for the top bolt hole due to the thickness of the TB.
Old Mar 31, 2006 | 03:46 PM
  #146
BigTex's Avatar
I used a plain socket in something like 5mm or 6mm. It fits directly over the torx points and lets you unscrew it. Otherwise, put two nuts over the bolt, tighten them against each other, and use one to back the stud off the flange.
Old Mar 31, 2006 | 03:53 PM
  #147
F8L Z71's Avatar
Thanks bro
Old Apr 2, 2006 | 11:51 AM
  #148
BigBlackAv's Avatar
i used vice grips...they weren't in that tight.
Good luck!
Old Apr 4, 2006 | 06:39 AM
  #149
JimS's Avatar
Good luck!
Vice grips may ruin the studs. The double nut method works and is the safe bet if you don't have a set of the Torx sockets. I had to get a set. Too cool a tool to not have
Old Apr 4, 2006 | 07:26 AM
  #150
BigBlackAv's Avatar
it is definately better to have the right tool...but to get them out quickly the vice grips worked well, like i said they were not that tight. And others have had luck w/ them too (I was not the mastermind of this idea).
Good luck!
