Compound boost
Old Jun 11, 2008 | 09:20 AM
gdev_'s Avatar
Default Compound boost
I've been looking at the trick front high mount turbo system, and with several Whipple's for sale (cheap!) recently, I been toying with the idea of a compound boost setup. I know the complete kit might not be compatible with the 07/08+ trucks, but will the manifold and head unit work? Where could I find out if the manifold and supercharger will bolt up and actually have the pulleys line up w/o TOO much fabrication?
Thanks in advance.
Old Jun 11, 2008 | 09:59 AM
00ChevyScott's Avatar
Wearin' da big hat
Too much trouble. I'd just pick one or the other.
Old Jun 11, 2008 | 10:33 AM
KySilverado's Avatar
I've been toying with the idea myself. Haven't gone to deep with it but think a vortech or pro-charge would work with my maggie setup. Think could get the pullies lined up okay but would have to go with an 8 rib setup.
Old Jun 11, 2008 | 02:43 PM
BigCountryx's Avatar
Now you are a sick man... could you imagine the whine!
Maybe a Weiland 8-71 would fit under the Maggie
Old Jun 11, 2008 | 04:19 PM
TrickTurbo's Avatar
Truck Sponsor
Thanks in advance.
I think your whipple will not fit, with the Trick turbo in place. could be wrong
Our products are on sale right now..
Let me know if there is anything I can do for you.
Rick
Old Jun 11, 2008 | 10:34 PM
Hawk179's Avatar
Why......Worst idea. Nothing like compressing Air twice.
Old Jun 11, 2008 | 10:40 PM
TurboJohn6's Avatar
I was thinking the same thing....Why? It might look impressive but I would not think it would work to well. Too many headaches too!
Old Jun 11, 2008 | 10:45 PM
Stoichiometric's Avatar
If you keep each device working in its adiabatic peak you may end up with an efficient high boost level. In theory of course. Even one after market power adder is complicated enough, adding another will 'compound' these issues (pun intended). Someone still needs to try it and report back.
Old Jun 11, 2008 | 11:27 PM
kbracing96's Avatar
Best of both worlds Off idle instant torque of the supercharger, and easy adjustable high boost numbers for the top end!!
Some day I will do this!
Old Jun 12, 2008 | 12:07 AM
geestyle4's Avatar
the 03 04 cobras have a kit so you can run twin turbos though the stock eaton blower its called the hellion http://www.hellionpowersystems.com/data.twinturbo.html
