Code 0315
Old Sep 28, 2005 | 10:31 PM
TchargedLS1TA's Avatar
Default Code 0315
After the Nelson tune, I got code 315 from a check engine light.. I had Autozone pull the code, bu they dont have the brainpower to erase it.. Is it the crankshaft position fault code? Will it clear itself after a few key cycles?
Old Sep 29, 2005 | 11:19 AM
Mort's Avatar
Cool
You will need to take it to someone with the appropriate software to do the crank relearn procedure. The dealer can perform this operation with the Tech 2 or you can phone around and see who else may be able to do it. I guess it only takes 5 minutes or so to do.
Old Sep 29, 2005 | 10:02 PM
I dont get it, do they need to reprogram something or is it just a code that can be erased? We have a MODIS Snap-On scanner at my work, will it be able to get rid of the code or is it better left to the dealer.. I would rather avoid the dealer since they would probably charge me an hour labor for a 5 minute fix..
Old Oct 3, 2005 | 06:46 PM
Mort's Avatar
Cool
Did you get the crank relearn figured out?
I am not sure if the Snap-On scanner can do the crank learn or not. I have heard that it can and cannot? Maybe it depends on the options you buy with the scanner. Check it out as it sounds like a fairly easy thing to do if it has the capability.
Old Oct 3, 2005 | 09:10 PM
Yea, I went to the dealership, sweet talked them, and they did it for free.. It was definatlely something I would not have been able to do with the MODIS- only something that can be done with the Tech 2..
Old Oct 10, 2005 | 04:15 PM
Scott Mills's Avatar
Is it bad to drive the truck with this code illuminated? does it effect the truck?
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
