catch can...
not sure if you guys have seen or used this one. I saw it last night in a Jeg's, it was listed as "new"...
It looks alot like the ones at Home Depot and that bothers me because the ones there have a warning label on them stating that the bowl is NOT compatible with petroleum products...for air/water separation only.
Due to the stated use for this, I would think this one is different, but who knows? But, at $39.99, it is much cheaper than the aluminum ones...
Air oil separator is designed specifically for vehicles with positive crankcase ventilation systems. Prevents oil blow-by from being displaced into the intake tract on engines where crankcase pressure is high such as (but not limited to) power adder or high RPM applications. Features a clear polycarbonate bowl for durability and easy viewing, serviceable 5 micron element and a twist/turn drain. Easily cleaned with household soap (dishwashing liquid), thoroughly rinse and air dry (do not use compressed air). Includes mounting bracket and two 1/4"NPT x 3/8" hose barb fittings. Always route away from heat sources. Maximum pressure of 150psi.
nic351
Sep 24, 2015 09:43 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
