carbed 350 supercharged timing ?
Old Apr 27, 2010 | 03:41 PM
BAGGEDBURBAN305's Avatar
Registered User
Default carbed 350 supercharged timing ?
what would be a good timing for a carbureted supercharged mild small block?should i even hook up the distributor vaccum advance at all?should i tinker with the msd boost retard some?a/f ratio is good and i have timing set to 0 until i can figure out where to put it.heres a little more about the motor
stock 350 short block
intercooled vortech v1 2.95 pulley 8psi
ported edelbrock 60859 heads
crane 467 494 camshaft
1.6 rocker arms
airgap intake
demon 650 blow through carb
73 jets up front no jets outback
aeromotive regulator
dual walbro 255's
msd btm box
msd hei distributor
Old Apr 27, 2010 | 04:07 PM
blueflamed03's Avatar
hard to really say. You have the MSD880 I think timing adjustment? Having vacuum advance is really dependant on car weight, stall and gears. So if you have a 3500 stall and 3.73's, no, IMHO you don't need it. Usually, 12-14 initial, 34-36 max, depending on many factors. But read the plug at a WOT, shut car off, coast and read it.
2500ZL1
Jan 25, 2016 06:30 AM
slowlsx
Aug 13, 2015 08:28 PM
Boombastic
Aug 5, 2015 11:38 AM
4B11T
Jul 13, 2015 03:48 PM
