-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   Can this cooler help keep temps down better??? (https://www.performancetrucks.net/forums/forced-induction-159/can-cooler-help-keep-temps-down-better-463553/)
01 BERGER CAMARO SS Jun 3, 2010 11:57 PM
1 Attachment(s)
Full Air to Water Heat Exchanger Kits Here!
Water to Air Intercooler Radiator - 26x7x3.5 (Type 101)
[WAT001026]
These radiators are designed specifically for use in air to water intercooler applications.
At seven inches tall, they are perfect for mounting in front of the radiator on most cars.
With four strategically placed mounting points, they are easily mountable with the water inlet and outlet on either the left or the right.
All aluminum construction provides maximum cooling with water or antifreeze/coolant.
Water inlet and outlet are 1/2" NPT female threads, just like most air to water intercoolers.
These radiators feature a drain plug on the bottom for incredible installation flexibility.
In case you wish to include a water temperature gauge in your installation, these radiators feature a 1/8-27 NPT tap for a temperature sending unit. They ship with a plug installed in case you do not wish to use this feature.
Radiator is packaged well and double-boxed before shipping.
Depending on your air to water intercooler setup, these are usually good for over 1200 HP.
Could also be used as a radiator for small-engine or some drag racing applications.
TIM Z Jun 4, 2010 10:55 AM
How much?
Are you seeing high IAT's now?
blownss06 Jun 4, 2010 11:32 AM
You have a tvs so your iat temps shouldnt be high. I on the other hand have a mp112 and i need to finds ways to keep my temps down. Where did you find that at?
01 BERGER CAMARO SS Jun 4, 2010 12:06 PM
I found it at frozenboost.com and it list for 179.99+shipping. Im not seeing high iat's but anything helps
Red04Silverado Jun 4, 2010 12:18 PM
LOL thats the one I was looking at for my maggie setup
Atomic Jun 4, 2010 12:42 PM
that doesnt look much better than the included magnacharger heat exchanger
01 BERGER CAMARO SS Jun 4, 2010 12:46 PM
i think it does, the one that came with the kit works but if theres a better one then why not. Im in deep south texas and its hot as hell. If it can keep temps coolent temps lower then its worth buying
AKlowriderZ71 Jun 4, 2010 12:47 PM
I don't know if anybody has used one of those yet, but with those dimensions, it should have quite a bit more surface area for cooling efficiency. I'm not sure if it will fit behind your grille without some cutting, especially if you have a larger tranny cooler. If you don't mind a little cutting, I think you could make it fit.
Wait, I see you have an '09. I think those have more room...
blownss06 Jun 4, 2010 01:39 PM
My stock mp112 is about 24-7.5-1. The one he mention is longer,1/2 shortter and 2.5 thicker. So yes it does have more surface area.
one fast ss Jun 4, 2010 04:13 PM
5 Attachment(s)
I have this one on my truck with e-fans wired to a switch in the cab. It fits behind my grill but my tranny intercooler was already re-located where the bumper is
heres some pics
