Cam suggestions for Magnacharger
Old Oct 21, 2010 | 07:12 PM
  #21
03 True Fire's Avatar
thanks dubbed z71! that vinci trucker sure does have a split that id want.. is it that cam or the torquer v2 that needs the 7.45 pr's? or something like that i forget where i read that. also what do you guys think about the stall speed for a torque converter? i was leaning torwards a 2800 since it is a light truck.. i know regardless im going to light the tires but i dont want to spin for hours nailing it with a 3200.
@lucille when are you plannin on throwing the mag on? i want to see some numbers!!
Old Oct 22, 2010 | 08:56 AM
  #22
Lucille's Avatar
Hopefully before the end of the year. It's currently being used to design some cooling improvements
Old Oct 24, 2010 | 02:28 PM
  #23
fastnblu's Avatar
Originally Posted by jiar577
Why get an off the shelf cam when you can get one designed to suit YOUR needs? Granted, I don't have experience with custom cams, or FI for that matter, and I'll be guilty of running the 212/218 with the R-TVS, but it's supposed to work fine with the blower and it's already in the truck, a custom one is next.
There's no other way than custom cam in my book, specially when going FI: With all the $$$ I'm dumping on this thing I don't wan't to leave anything on the table, and this is for my DD. If I could only get a nice lope out fo a blower cam that'd be the icing on the cake. Of course not going to happen.
Damn, I should install the blower instead of loosing my time here
Same here, 212/218 is what I have & I'll be using. Supposed to be good, just as GT2-3, Vinci Trucker. Also, LS6 & it's cheap to get, but some on here say LS6 can be improved upon. Any of those I'd think. Most seem to stay around these, but LEP has some too. I just don't know many on here running em, but Zippy could probably provide some insight on the LEP cams.
Originally Posted by Lucille
Just installed my Pat G spec'd blower cam. Picked up 74.6 peak HP and 56.4 peak TQ. Even better I picked up (from 3000 rpm on up) an average of 36.8 HP and 39.7 Ftlbs of torque. Keep in mind that this is a small cam on a 6.0 that's nearly stealth.
Can't wait to see what it will do with the maggie!
Nice gains for sure!
Old Oct 24, 2010 | 08:02 PM
  #24
Atomic's Avatar
I have a gauge for that
I had a 218/230 117 LEP cam in my 408 and loved it.
Old Oct 31, 2010 | 02:01 PM
  #25
The 212/218 is a good cam down low and mid range. Ive enjoyed using it over the past 5 years - would recommend opening up the exhaust duration to say 224 or 230.
Old Nov 2, 2010 | 01:12 PM
  #26
guero68's Avatar
might not be the perfect but i went with a comp XER 224/230 114lsa on a 08 5.3....seem to work pretty good...i dont have any numbers but has a nice lope..
Part Number: 54-444-11
Old Jan 19, 2011 | 10:32 PM
  #27
DanszToy's Avatar
HI, I am interested in using a cam like the one you have in your pickup and was hoping you would share some info. I have a 6.0L with a maggie 112, shorty 1 3/4 headers,90mm TB, Patriot HDs. I'd like to know how smooth your idle is, where peak hp & tq is, dino #s, and where you bought your cam. Also any input on the smaller blower. Appreciate your help. Dan
Old Jan 19, 2011 | 11:08 PM
  #28
DanszToy's Avatar
sorry, new at this. My question was for OLD MOTORHEAD.
JordanH
Aug 8, 2015 07:59 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
