Cam selection for LSX Turbo build
Old Jan 14, 2010 | 01:00 PM
BKnBLK05's Avatar
Just a FYI but 4" bore x 4" stroke is a 402ci.
As for cam selection, what type of hot section will you have? Log, flipped stock manifolds, equal length primaries? Where do you want your redline to be? SC, EC or CC truck? Lots of variables.
Yea I was just roughing it,But to be exact it's 4.070" Bore, 4.000" stroke,6.125 rod,So whats that like 416-418? And Equal primary,full 3" exhaust w/xpipe redline bout 6600,rcsb,3.42 gear,6l80e,and yea I'll probably wanta go bigger on the turbo,Planning on putting 16-20 lbs of boost down
Old Jan 14, 2010 | 02:35 PM
1989k1500's Avatar
So your doing the turbo rear mount then? Why would you do an x pipe when its y'd together after for the turbo?
Old Jan 14, 2010 | 06:21 PM
BKnBLK05's Avatar
Exhaust is not a lock yet,still specing that out too,Thanks youv'e gave me sum food for thought,Really trying to nail this cam selection down so I can get this motor built....
Old Jan 14, 2010 | 08:36 PM
MikeGyver's Avatar
Originally Posted by BKnBLK05
Yea I was just roughing it,But to be exact it's 4.070" Bore, 4.000" stroke,6.125 rod,So whats that like 416-418?...
416.320993528 in.³
Old Jan 14, 2010 | 08:42 PM
eviltwin_1987's Avatar
your motor WILL have massive back pressure problems if you do a front mount 76 and i dont see a 76 feeding 20psi to any 414ci motor. And if you are going to throw around that kind of money on an LSX you should do 6 bolt heads or the block would just be a waste of money over a LQ4/LQ9 block. Sounds like you are ready to throw down big money but are just going to end up with abunch of parts that dont work well with eachother
Old Jan 15, 2010 | 08:44 PM
BKnBLK05's Avatar
Seems like youv'e been doing this awhile,and have done a few,So assume you have a 20k budget,how would you do this build,with the goal of putting as close to 1000rwhp down and be totally streetable,That why I'm here to get sum good knowledgeable input......thanks in advance
Old Jan 20, 2010 | 10:23 AM
I would do a 402/408 with o-ringed block and heads with thick deck heads and a 91mm or bigger turbo. A 20k budget won't get you far with a lsx block. If you are buying a complete short block I would call virginia speed. Shawn there is a genius. Once you hit the 1000hp mark things get real expensive.
Why do you want close to 1000whp? For bragging right or is there a certain et that you need that power to reach it?
Old Jan 20, 2010 | 03:23 PM
BKnBLK05's Avatar
Yea I'm trying to get into the 9's....And The LSX block,machine work,callies crank,rods,pistons,complete short block with custom ground cam,springs,lifters is only 7 grand,I've gotta set of new LS3 heads that I can use,But was considering those LSX-LS3 Heads (2 grand) from Chevrolet for better clamping for the hi boost,Thought I'd run this 70mm garrett on a t4 flange that I have as well for now and then upgrade in the future...
Old Jan 21, 2010 | 08:47 PM
If i were you i would only run a t6 and something 91mm or bigger. But i must insist if you are going lsx block it would be a waste of money not to get 6bolt heads to begin with. Upgrading later will just cost alot more down the road.
chopperloco
Jul 10, 2016 10:45 PM
USMCvet0311
Aug 14, 2015 10:28 PM
Ammadien
Jul 22, 2015 08:50 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Cowboy17
Jul 9, 2015 06:18 PM
