cam selection
Old Nov 25, 2012 | 01:59 AM
maze2525's Avatar
Default cam selection
So that everyone is up to speed. I'm building a Chevy 408 with ls7 heads and the edelbrock pro flow intake. For injectors I'm going to get injector dynamics 1000. Bought a trick performance turbo set up. T4 flange Borg Warner 80mm, 3.5 in dp. Now I just got to pick a can and this is what I was thinking TU2 236 236 .578 .578 112.5. I know have build trans and stall but its also a dd that just wanna have fun with and take to track every now and again. I'm open to ideas on cam
Old Nov 25, 2012 | 01:03 PM
gamble686's Avatar
You plan to DD that setup?! I hope you have a good back up vehicle. Once you start getting mod crazy it takes a while to get it dialed in enough for daily work. Also will be one hell of a street vehicle. Anyways that cam should make a great deal of power when it's up on boost.
Old Nov 25, 2012 | 01:49 PM
maze2525's Avatar
ya. had pretty much same 408 in my 05 just it was a na motor that was 10.5:1 drove it as my dd. should be well behaved if keep it out of the boost
Old Nov 25, 2012 | 02:58 PM
Atomic's Avatar
I have a gauge for that
I would want some more lift with those LS7 heads. Duration also might be a littler lager than you need for a DD, and split is also a little tight for a boost cam. I would look more for something in the 225/225 620 620 117 range, depending on what the flow chart for your heads looks like.
Old Nov 26, 2012 | 06:52 PM
maze2525's Avatar
here is the flow chart for my heads. love the sound of a choppy idle tho thats why i wanted the tu2 cam that i posted.
393 at .700
and this is the cam that i had in my 05 for a dd on 112... 237/242 .603"/.609
stock48
11
Aug 18, 2015 05:55 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
