Cam profiles for 347ci D1sc 12lbs boost
Old Oct 18, 2006 | 02:03 PM
Blown06's Avatar
8 Second Truck Club
Default Cam profiles for 347ci D1sc 12lbs boost
3200 yank converter
3.73 gears
4800lb rcsb
not daily driven
any suggestions?
Old Oct 18, 2006 | 02:08 PM
zippy's Avatar
What heads are you running?
Old Oct 18, 2006 | 02:22 PM
Blown06's Avatar
8 Second Truck Club
the 5.3 heads, if they will work. Haven't figured out yet if the chamber is big enough to get the compression down to around 9:1. Any ideas on this are welcome as well.
Old Oct 18, 2006 | 03:03 PM
Bad_Apple's Avatar
I just ordered a ED Curtis Cam, he can hook you right up.
Old Oct 18, 2006 | 03:05 PM
Last Call's Avatar
TOTM: January 2007
I would think that the 5.3 heads would riase compression. Why not 6.0 317 heads. They are relatively cheap and will lower compression.
Old Oct 18, 2006 | 09:06 PM
03sierraslt's Avatar
They also have larger valves and higher flow #'s
Old Oct 18, 2006 | 09:17 PM
ranwalk's Avatar
Mine is going under the knife for a cam change in November at Futral Motorsports. I'll be posting the results. Currently running a tiny cam 216/218 that was oringinally made to run with the Whipple. Will be going with somthing quite alot larger Cam specs to be determined by Allan at Futral.
D1SCSS
Jan 25, 2016 10:14 PM
Greatdivider
Sep 9, 2015 09:52 AM
fastjweb
Aug 15, 2015 10:47 AM
Atomic
Jul 22, 2015 03:41 PM
kdw8888
Jul 9, 2015 10:52 PM
