Cam for 408 stock heads and stock converter
Old Mar 26, 2012 | 02:26 PM
Q8 6.0's Avatar
Default Cam for 408 stock heads and stock converter
My stroker 408ci arrived Looking advice which cam to order for it. radix 2.7 pulley 10psi boost stock 6.0 heads... is there any link for cam shoot out comparison
Thanks
Old Mar 26, 2012 | 04:40 PM
a stock converter on a 408 is a bad idea if you ask me. If you want a close to stock stall speed, thats cool but get a stronger unit in there. We need more info on the setup to start suggesting cams. what truck, weight, purposes, gears, tranny, lots of variables
Old Mar 26, 2012 | 05:56 PM
skeet's Avatar
youre in that custom grind zone of cams, though off the shelf cams would work and probably work well, id go for something thats gonna get all it can out of the build!
Old Mar 27, 2012 | 02:33 AM
Q8 6.0's Avatar
Haha yah opps forgot to add truck info... 2005 Sierra single cab short bed 4.11 4x4 looking for low end torque cam. kit is high comp -3 flat top wiseco pistons around 12.1 compression. 10 psi boost. I'm still looking for overdrive crank pulley and hd belt tensioner.
Yes very good point on converter I forgot about that I'll just keep using it till it breaks then just get new one I like the stock stall feel.
Skeet I would love a custome cam but I want to order a cam today and have it here next week so I just want a tried cam by members of this great forum that has powerful low end torque on supercharged trucks.
I'll make a video when everything is installed in few weeks
Thank you
Old Mar 27, 2012 | 09:06 AM
1989k1500's Avatar
Are you putting a 112 on a 408?
Old Mar 27, 2012 | 09:49 AM
Q8 6.0's Avatar
Looking for some maybe 115 or 116 slightl smooth idle less blower clicking at idle...I am worried if I put a 112 the rotor pins inside the blower will start to hit that spring in the nose make a clicking sound. Is there a solid isolator to replace the stock spring in the nose.
Also would like people to know The search sux all I see is ford 408 cams there is nothing for ls1 with google search.
Dose anyone with radix and 408 ever installed a cam there is nothing on google
Old Mar 27, 2012 | 12:06 PM
1989k1500's Avatar
I don't think I have seen anyone with a 112 and a 408. I don't know if you will get 10psi out of it, that static compression will help you some so the supercharger doesn't have to fill as much cylinder.
Atomic had a 408 and a tvs1900 and it made 8psi. Could Pm him about the cam.
Old Mar 29, 2012 | 11:35 PM
Atomic's Avatar
I have a gauge for that
I had a similar setup, 408, 11:1 compression, stockish 317 heads, tvs1900 with a 2.8" pulley
It made about 8psi. Torque was freaking insane.
I had a 218/230 .600/.600 117 cam and it sounded basically stock, drove like stock, and had awesome midrange.
Old Mar 30, 2012 | 12:10 AM
caddy03pimpin's Avatar
A cam option For the 408 and the 112 blower I was recommended by a few company's 224 228 114 this was a few years back i, I ended up going with a 236 248 112 but I moved up to the 2.8 kennebell , but I do know someone who is using this cam in 408/112 combo
Old Mar 30, 2012 | 01:58 PM
old motorhead's Avatar
Something like a 224/234 116 would play nice with your cubes. Start saving for heads and a TVS2300 right now
