CAI for TVS2300
On the Outlaw box....
Get rid of all the internals and keep the shell. Take a piece of Lexan and cut/drill new end plate where you can add four longer screws, flat washers, lock washers, plumbing valve gaskets, foam strips, two new 4 inch dryer bulkhead vents (home supply or PEP Boys) back to back on either side of Lexan center of shell (drill, RTV, and bolt together), Spectre 4 inch tubing and rubber connectors (i.e. PEP boys) and run all to suit your setup. I was well under $50 on this part. Then just add any 4 inch filter of your choice clamped to the new 4 inch connector inside your Outlaw shell. I used the biggest one I could find at the time. Nothing has come loose or cracked in the year it has been there. I am also toying with the idea of mounting some lights inside the shell that I can switch on/off just for grins to look through the Lexan at the filter.
Also I added 100 mm MAF that I leave there whether actually using or othewise on 2 BAR. I also got a LS2 90 MM TB and DrX Link to replace the stock one.
cheers
cheers
cheers
cheers
I used Air-Raid 700-470 replacement filter.
Type - Cone
Flange - 4"
Base - 6"
Top - 4 5/8"
Height - 9"
I am going to look again eventually to see what else is out there now, but this is what I found and have been using since the end of 2009.
Type - Cone
Flange - 4"
Base - 6"
Top - 4 5/8"
Height - 9"
Here are a few more brands/sizes as big or bigger to choose from I found this a.m.
K&N RE-0870 (same dimensions as the Air-Raid)
K&N RD-1460 (this one looks promising)
Flange Inside Diameter: 4 in (102 mm)
Flange Length: 1 in (25 mm)
Flange Type: Centered
Height: 9 in (229 mm)
Outside Diameter: 7 in (178 mm)
K&N RE-0880 (probably too tall)
Flange Length: 1.75 in (44 mm)
Height: 14 in (356 mm)
Top Outside Diameter: 4.625 in (117 mm)
Air-Raid 700-480 (alt. 701-480)
Base: 6 in
Height: 10 in
Top Outside Diameter: 4 5/8 in
Air-Raid 700-490 (alt. 701-490)
Base: 6 in
Height: 12 in
Amsoil Number EaAU4090
Product Style Round Tapered
Base OD 6"
Flange ID 4"
Flange Length 1.75"
Flange Type Center
Media Height 9"
Top OD 5"
Base: 6 in
Height: 10 in
Base: 6 in
Height: 12 in
Base OD 6"
Flange ID 4"
Flange Length 1.75"
Flange Type Center
Media Height 9"
Top OD 5"
Base: 6 in
Height: 10 in
Base: 6 in
Height: 12 in
Base OD 6"
Flange ID 4"
Flange Length 1.75"
Flange Type Center
Media Height 9"
Top OD 5"
Base: 6 in
Height: 10 in
Base: 6 in
Height: 12 in
Base OD 6"
Flange ID 4"
Flange Length 1.75"
Flange Type Center
Media Height 9"
Top OD 5"
I'm speed density tuned. No MAF. Trying to get all 4" from the bigger air filter to the t'body.
Big props to "Chavette". His filter swap suggestion worked like a charm. We used the Amsoil filter. With the Amsoil filter, boost went up well over 1 psi. Thanks Mike! If any of you Houston boys get a chance to check out his Avalanche, do it. It's a work of art.
