buying 100%meth
Old Nov 6, 2007 | 10:09 AM
PPI Typhoon's Avatar
My local shops kept running out of it, so I just would go down and pick up a gallon of denatured alky. Worked rather well.
My best was running 26psi on the stock turbo, with 87 octane gas in the middle of summer. Basically no knock.
Old Nov 6, 2007 | 10:54 AM
vanillagorilla's Avatar
26psi on a stock Ty turbo? Wow! I thought they just blow hot air at about 20psi I didn't know they could do that. How much timing were you running on that run and what was the ambient temp? A2A IC or stock A2W?
Old Nov 6, 2007 | 03:00 PM
Yeah, I ran it with the wastegate unplugged and it churned out 26psi. Now you are correct, when I went to dyno it, anything over 21psi wasn't giving me any more power. I still managed 455 ft lbs of torque though.
Oh and here is a quick video where you can tell when my alky kicks in (homemade setup with a hobbs switch). You can see the front end of my truck start to lift up right before I take off
http://www.danhanisch.com/ppityphoon.wmv
Old Nov 6, 2007 | 04:18 PM
whoopassracer's Avatar
Originally Posted by JJ_NLTO
Hey you can buy it there at the track, and its cheap too, I'm gonna try it since i was using 50/50 cause I read somewhere that 50/50 could make an engine bog down, did you try spraing it at higher boost? Allen did that with mine and problem fix.
i raise my my boost switch to 5lbs, which before was at 3lbs, and only spraying washerfluid, which is what 80%water 20%meth, or something like that, so i wanna try 100%meth,
and my truck sounds like it bogs noth even a spit sec off the take off, then it picks up quick.
maxspeed05V
Aug 26, 2015 04:21 AM
MS3Z
Jul 30, 2015 06:17 PM
