Bullet style intercooler set up build
Old May 12, 2006 | 02:22 PM
  #31
TG02Z71's Avatar
Originally Posted by quicksilverado
I went to the track last summer. Got there 2 hours before racing started. Made a couple of passes and then they saw something and kicked me out off line. Turns out it was condensation from the AC. Almost 3 hours had passed since I used it last.
Makes me just want to take the damm belt off the compressor and be done with it. Your scaring me man!!!!!
Old May 12, 2006 | 02:48 PM
  #32
TIM Z's Avatar
11 sec. Truck Mod
good luck on your project! but with all the headaches you have been having why not just buy the STS FMIC? my intake temps with the fmic are only 5-12 degrees over ambient. no headaches or worries, just cool air! Pm me if you want one at a big discount!
Old May 12, 2006 | 03:34 PM
  #33
unklej's Avatar
Have fun at the SAE Comp Duwem, Check out the Rutgers team, I still help my former team out with engineering support and guidance now and then. I can't wait to drive this year's car, it should be fun.
Old May 12, 2006 | 03:47 PM
  #34
TG02Z71's Avatar
I'm thinking I'm f-ing nuts, but I want something different even if it gives me 100 more gray hairs!!
Old May 14, 2006 | 06:30 PM
  #35
duwem's Avatar
damn engineers..always complicating things
I got to drive the formula car today, in the rain but holy hellll, nothing like 12000rpm redline, 6 gears, paddle shifting and one hell of a low ride height and suspension.
Old May 14, 2006 | 06:40 PM
  #36
TG02Z71's Avatar
Wish I was there man.
Old May 15, 2006 | 07:57 AM
  #37
vanillagorilla's Avatar
Those were the days. Try adding a turbo into the mix.
Old May 16, 2006 | 10:47 AM
  #38
TG02Z71's Avatar
Ok, did some more simple math, now I need a flow engineer to look at it.
(121) .375" diameter holes =13.36 surface area total.
(61) .5" diameter holes =11.98 " ".
(31) .75" diameter holes=13.7" ".
Combination of (61) .5" and (12) .375" diameter holes=13.05 surface area total.
So what would yeild the best combination of heat transfer vs flow??
For comparison the STS 2.5" pipe would have a 4.91" total surface area opening, and if its a 3" pipe it would be 7.07" total surface area.
Old May 16, 2006 | 09:43 PM
  #39
MikeGyver's Avatar
If you are saying that 121 3/8" circles have 53.46 sq. in. area, as in Pi x radius squared, x 121, then yes, your math is pretty simple. You made a similar mistake in the second post in this thread, which I corrected. Pi x radius squared (.1875" x .1875"), x 121, does not equal 53.46. Your calculations for 1/2" and 3/4" holes are just as wildly wrong as the 3/8" numbers. So are the 2 1/2" and 3" pipe numbers. If you are trying to figure surface area of 36" long tubes, the formula for 121 .375 tubes is: Pi x diameter, x 36, x 121. That comes out to 5132 square inches. I'll let you figure out the others.
Old May 16, 2006 | 10:01 PM
  #40
TG02Z71's Avatar
Thanks for pointing out my brain fart. I did diameter squared like a fool.
I will correct my other post.
