Boosted 370 swap to 408?
Old Feb 20, 2014 | 03:05 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by AKlowriderZ71
I'd do the 370, but bump that compression ratio up to at least 9.5:1, tune the **** out of it & let it eat. Your 11.50's should be in the bag.
Stock crank will be fine, get some forged rods for peace of mind. I think the turbo you already have will get it done.
370's been doing big things, hell STONE stock cube **** has been doing big things.
Old Mar 15, 2014 | 07:45 PM
AkSSS's Avatar
Just to update this. I have decided to run the 370. I am going to run the diamond pistons and I bought some scat h-bra am rods. Then some new main studs for the stock crank.
Then I got a stage 2 turbo cam from Brian Tooley and some tfs 220 heads(massaged by Tooley). I also bought an edelbrock pro flo and some id1000's to top of the motor. I'll be putting in dual 400's into a 06 fuel tank for fuel.
Did I miss anything?
Old Mar 15, 2014 | 07:47 PM
AkSSS's Avatar
Oh yeah. I'm going to change my turbo to a turbonetics 76/76. I'm pretty sure that should be enough turbo?
Old Mar 15, 2014 | 08:47 PM
quez82's Avatar
I'm running it now, I would imagine it would be enough. Figure it would get me to 6k rpm threw the line. 700-800awhp being modest.
Old Mar 19, 2014 | 05:35 AM
slowec's Avatar
times and mods in sig for reference, 4500 race weight. leaving S O F T
Old Mar 19, 2014 | 11:04 AM
AkSSS's Avatar
Well that's pretty close to what Im going to have on my motor. Specs are
Diamond -15cc dish pistons
Scat rods with arp 2000 bolts
Stock crank with arp mains
Tooley cam 226/231 605 598 113+4
Trick flow 220 heads worked over by Tooley 65cc chamber they will bring my compression up to 9.4 from 8.8
Edelbrock proflow intake with 90mm tb
Id1000 injectors
Dual walbro 400 pumps
Built 4l80
P.I. Multi disk 3200 converter
That should be about it, replacing timing set, lifters and trays. I might have missed a few things but this should run pretty decent. I will have to run my master power turbo for a couple weeks after I finish the build to recoupe some cash. Then I will either go with a bigger turbo. Either 76/76 or 76/75.
I am going to get 4 drag radials for it to go with my caltracs. I have never been able to hookup the first truck length or two. Going to go with either the nitto 555r's or the nt05r on my stock 20's. That should hook pretty well. I can't remember my last weight. But iirc it was about 5650 with me and a little over 1/4 tank of fuel and my 22's on the truck.
I think this will get me to my goal and a little more.
Old Mar 19, 2014 | 04:38 PM
12secss e.mack's Avatar
do a set of kateck main caps if your going to run 20lbs of boost and more......I ran 25lbs of boost and broke all my stock main caps on the even side on a built 370ci on a new motor
Old Mar 19, 2014 | 04:43 PM
AkSSS's Avatar
Did it do any damage to your block or crank? That doesn't sound healthy. I wonder if the stock crank will take that much with those main caps?
Old Mar 19, 2014 | 07:45 PM
bigboy576103's Avatar
there is alot of good information here. kinda makes me rethink my 404 lol..
although my 404 feels stronger because of the torque but i think my old motor reved a bit faster.
maybe others will tell there experiance with that.
Old Mar 20, 2014 | 04:42 PM
no, crank was ok but callies rods were elongated at wrist pin side .
