boost vs compression/ring gap/heat
Old Oct 16, 2019 | 02:46 PM
TXsilverado's Avatar
Hold my beer and watch this. Jeez
my life motto LOL. What makes you say this?
Old Oct 16, 2019 | 04:01 PM
Atomic's Avatar
I have a gauge for that
Being WOT for 10 seconds vs 5 seconds is a looooooong time
Old Oct 16, 2019 | 04:17 PM
so 15 lbs is too much, even with meth injection? that's boring lol.
Old Oct 16, 2019 | 04:21 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Do you even know the actual ring gaps in your engine???
Do you know what type and brand of rings you have???
Wiseco Chart Above
Mahle/Clevite chart above
Old Oct 16, 2019 | 04:56 PM
03sierraslt's Avatar
high compression, moderate boost, and high IATS. Your looking at boost as a number, on your setup you are gonna have to play around with boost and timing. You may make more at 12lbs with decent timing then 15lbs with no timing. For your CR and blower E85 would be perfect.
Old Oct 16, 2019 | 05:06 PM
1FastBrick's Avatar
Old Oct 16, 2019 | 05:29 PM
I didn't measure it myself, but the TSP build sheet advertises it at .019 top and .021 2nd. It was built for N/A and small Nitrous...boost was an afterthought from the original builder. it has the TSP Weisco pistons so I assume it is running the weisco rings as well.
the weisco recommendation for "moderate" turbo (whatever that means) suggests .020 first and .022 2nd. pretty dang close.
Hold my beer and watch this I guess....It either goes, or it blows. I hope it goes.
Old Oct 16, 2019 | 08:44 PM
To compare, mines .022/.024
Old Oct 18, 2019 | 11:01 AM
CarGeek's Avatar
I did .026 first ring and .028 2nd ring for mine just in case I really turn it up. But i think .022/.024 is more common for the turbo guys on Sloppy Mechanics. Then again, there is several running stock ring gaps with high boost and haven't blown up..yet. lol
Old Oct 18, 2019 | 02:58 PM
Well there is a difference between stock rings and aftermarket rings also, stock rings are weaker and should have a bit more gap to them.
