boost referenced regulator
Umm, not quite. Boost referenced FPR's dont work the same way in vacuum as they do under boost. Think about what you said for a minute, if it were true there would be no point in setting regulators since it would only be right at one vac setting. That screw on top is a physical stop for the regulating mechanism, boost can push it down more, but vac cant suck it up any more because the screw stops it.
Swerve7rpm2000 is correct, it is up to the tuner. If you use boost reference, the injector flow rate vs. kPa table will have the same values across the board, and if your regulator does not have a vacuum hose, the same table will vary according to the injector data. The VE tables will be different for each type of regulator.
