boost problem
Old Sep 20, 2009 | 06:06 AM
sowaidi's Avatar
Default boost problem
the problem is the boost controller is set at 12 psi (aem tru boost controller). im suing an sts turbo on a 6.0 with a t56. the boost fluctuates and doesnt stay on 12 but reaches it in some runs and other runs gets 7-8 only in 3+ gear. 1st and 2nd gets to 5-6 psi. i dont know if the problem is from the controller or the wastegate.
Old Sep 20, 2009 | 11:15 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
the turbo maybe to small....
i'm not a turbo-guru i am still learning but maybe someone else will chime in
Old Sep 20, 2009 | 05:13 PM
sowaidi's Avatar
the turbo is smaller than what you would have behind a 6.0 but i have it since it helps boost in lower rpms. its a 60-1
Old Sep 20, 2009 | 05:59 PM
TURBHOE's Avatar
do you have stock manifolds or long tube headers?
Old Sep 20, 2009 | 07:04 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
check the diameter of the vacuum lines to the wastegate -- too large of a line will act like that.
ferrellrooster
Mar 6, 2025 03:22 PM
GMCtrk
Dec 18, 2015 04:47 PM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
lxcoupe
Jul 21, 2015 02:12 AM
