boost limits of mild 370?
Old 03-22-2012, 02:10 PM
james8997's Avatar
Default boost limits of mild 370?
I kno that's a very broad question, a lot of factors come into play such as tuning, intercooler efficiency, octane of fuel your running, etc.
I'm building a 370 using a stock lq4 crank, compstar rods and either diamond or weisco forged pistons, 317 heads...just wondering what the upper limits of boost a setup like this could safely handle? With and without meth
Old 03-22-2012, 03:36 PM
bmd_CL's Avatar
enough to make dang near 1000 im sure...
Old 03-22-2012, 03:47 PM
f4tal's Avatar
Meth will definitely be needed. But everything else should be able to see at least 1k hp
Old 03-22-2012, 03:55 PM
I have a gauge for that
Atomic's Avatar
- when you start to get uncontrollable detonation
- when you start to lift the heads
- when the intake blows apart
which ever comes first
Old 03-22-2012, 04:05 PM
james8997's Avatar
Lolz atomic I was thinking around 15 psi?
Old 03-22-2012, 04:09 PM
nonnieselman's Avatar
Theres several guys pushing 20-22psi thru the stock intake, and if you use good head gaskets and head studs then that shouldnt be a problem. Next on the list is your fuel, fuel is goin to be your determining factor.
Old 03-22-2012, 06:29 PM
james8997's Avatar
A fuel cell, sumped, a1000 pump and whatever injectors are needed
Old 03-22-2012, 06:39 PM
Atomic's Avatar
Run methanol and boost as much as your heart desires
...and I dont mean meth injection, I mean methanol as the primary fuel.
Old 03-22-2012, 07:14 PM
james8997's Avatar
we dont have methanol around were i live
Old 03-22-2012, 07:58 PM
THE-HOE's Avatar
subscribing, in for info
Quick Reply: boost limits of mild 370?
