boost levels, dyno vs street, hot vs cold
Old Oct 1, 2015 | 12:19 AM
Lthompson's Avatar
Default boost levels, dyno vs street, hot vs cold
Is it common to read a few pounds more boost on the street vs on a dyno? after some reading it kinda makes sense, because there is a little more load. Reason being, we read about 7.5 on the dyno. But i finally installed an autometer guage, and it will read 8-9. I just figured it was off by a little. Im wondering because im going to pulley down,, I was going to go down 4 points, which i was thinking would put me around 11.5.. But if my actual street boost is 8-9 that would put me at 12-13 lbs on the street... Im also reading that as it cools down you can see a boost increase. its on a stock 4.8, 5 speed rst. whipple. Thanks for your thoughts
Old Oct 1, 2015 | 01:03 AM
Blown06's Avatar
8 Second Truck Club
Yep, more load on the street. Dyno has a hard time simulating this load. Boost is typically higher than on a chassis dyno.
As the air gets better, you may see a slight increase in boost as well.
Old Oct 1, 2015 | 01:13 AM
smokeshow's Avatar
Mod with training wheels
I was on board with your theory until I read 'pulley down'... Turbos are affected by load, as boost can vary at the same RPM. But with a blower at a given RPM, neglecting the effects of weather, the boost will always be the same. Stab the throttle in neutral and watch the MAP readout on a scanner...if it doesn't smack the limiter before the scanner has time to sample the data, you'll see full boost from your whipple.
From what you said, I'd say there's a measurement difference... Dyno read 7.5, your autometer gauge reads 8-9...well they're not the same measurement device, are they? My cab boost gauge never exactly matched what my MAP sensor said, but I didn't pay much attention to it; they're just different measurement devices.
Old Oct 1, 2015 | 01:22 AM
Lthompson's Avatar
yeah the dyno measurement was through the map sensor i believe. "KPA" . Im just trying to get everything lined out and have a good idea where im going to be with everything before i order parts and head back for meth/tuning
Old Oct 2, 2015 | 12:45 AM
Blown06's Avatar
8 Second Truck Club
I had to go back and reread. I missed that it was a whipple. Disregard my comments and carry on.
Silveradorst07
Dec 31, 2015 12:04 AM
fastjweb
Aug 15, 2015 10:47 AM
JordanH
Aug 8, 2015 07:59 PM
Jake99
Aug 8, 2015 07:56 AM
NuckenFuts
Jul 9, 2015 08:45 AM
