Boost inlet pipe silicon couplers
Old Apr 13, 2013 | 07:33 PM
BUTTERB30's Avatar
Default Boost inlet pipe silicon couplers
WHO MAKES THE best SILICON COUPLERS for boost inlet side pipes cause the ones i bought are to short and keep blowing off!!!!!!!
Old Apr 13, 2013 | 07:59 PM
219boone78's Avatar
I ordered mine from siliconeintakes.com. they worked fine for me. I ordered a bunch cause i wasnt sure what ones would work best for my puzzle. And they returned the ones i didnt use. How much psi u running
Old Apr 13, 2013 | 08:39 PM
03sierraslt's Avatar
Make sure your pipes are bead rolled.
Old Apr 13, 2013 | 08:51 PM
BUTTERB30's Avatar
10-4 thanks guys
Old Apr 14, 2013 | 02:48 PM
BUTTERB30's Avatar
its always the pipe were it connects to the throttle body. No bead roll there just smooth
Old Apr 14, 2013 | 02:53 PM
AndysC3's Avatar
And get the band clamps. The warm gear clamps don't hold very well. And before you slide the coupler onto the pipe, spray some hair spray onto the pipe. It will help hold it together.
Old Apr 14, 2013 | 03:08 PM
I also got mine from siliconeintakes. They are decent and I haven't had a single problem with them. You Must use T-bolt clamps and you need some kind of a bead on the pipes. Either bead roll it if its aluminum, or you can do like I did with my 16ga mild steel pipes. I Just welded a bead around the ends, about 1/2" from the end of the pipe.
Old Apr 14, 2013 | 03:20 PM
kbracing96's Avatar
Or take a hammer and punch and put some dimples in the tube from the inside out. Clamping on those "high" spots will keep the coupler from blowing off. It works!
Old Apr 15, 2013 | 12:23 AM
2ktransam's Avatar
T bolt clamps are a must and bead roll the pipe.
Here is a simple way to bead roll the pipes that works great. I did it on both of my turbo trucks and have never had a pipe blow off.
How to make a Bead Roller - YouTube
Old Apr 15, 2013 | 03:03 AM
idahoblkss's Avatar
I get all my couplers from frozenboost.com think they are a 5 ply most in the industry are 3 or 4 ply .
