Boost with head bolts
Old Oct 11, 2015 | 10:53 AM
TXsilverado's Avatar
Default Boost with head bolts
What's considered "safe" with arp head bolts?
The combo is a 408 with ls3 heads and around 10.3ish compression. Pump 93 with 10 and 18 meth jets.
Old Oct 11, 2015 | 12:53 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
6 psi.
Old Oct 11, 2015 | 01:08 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I think you would be fine with ARP bolts, they won't stretch the way the TTY bolts do. Should hold at least 10-15PSI.
I think its more about your tune up than anything.
Old Oct 11, 2015 | 02:41 PM
Im wanting 18-20. Too much? No point in having a 3.6 blower and not letting it breathe.
Im thinking dominator efi or having it dyno tuned with something safe. It currently has a 2010+ camaro ecm so the no ve table thing is weird.
Old Oct 11, 2015 | 02:48 PM
George C....'s Avatar
Formerly ScreamingL
Swap to studs call it a day crank it to 25 psi and hold on
Old Oct 11, 2015 | 02:50 PM
i think 25 would require a custom pulley. A 3" is supposedly 20# on a 7.0. Would that boost be higher on a 408?
Old Oct 11, 2015 | 03:11 PM
Oh, this is supposed to be my street toy. It might see the track once...maybe
Old Oct 11, 2015 | 03:50 PM
BlackGMC's Avatar
Resident Retard
You gotta use Efilive to get the VE table. Hpt's version is not ready yet
Old Oct 11, 2015 | 04:05 PM
smokeshow's Avatar
Mod with training wheels
The VE won't be too difficult to tune since I'm assuming it doesnt have VVT. The later revisions of HPT have a coefficient to VE generator built into the editor now. You still running a maf? As for the bolts I think 20psi is pushing it. I couldn't say for sure though since I've only run the bolts once and swapped them out for studs before leaning on it.
Old Oct 12, 2015 | 01:24 AM
Blown06's Avatar
8 Second Truck Club
Many forget, I had arp bolts in my last motor. saw 23 psi from a d1sc and did not push. However, don't let that fool you. Several months before that, I pushed coolant on 14 psi bad enough that there was a puddle of water on the trailer under the motor and a water stain trail down the side of the block. See if I can find a pic..........
