boost creep or something else?
Old Mar 31, 2009 | 10:44 AM
kbracing96's Avatar
I don't think it's a WG location problem, To many successful setups running that way. I think you have the same problem as Qwik had with his PT88 on the 4.8. With your new turbo, you have less back pressure. Waste gates are designed to use both back pressure and boost to open at a specific boost level, generally at a 1:1 ratio. You want it to open at 7psi, you need a 14lbs spring (7psi of BP and 7psi of boost to open it). With your new and bigger turbo, likely your back pressure is a couple lbs less and the now you don't have enough boost pressure to open at the same PSI. You likely just need a softer spring. Qwik had to use a 5psi spring to get it to open at 10 psi. Make since?
Old Mar 31, 2009 | 10:55 AM
hellbents10's Avatar
LS1Tech Sponsor
If the setup is correct you should only need a 7# spring to have it hold a steady 7#'s of boost even with a 1:1 PR.
Old Mar 31, 2009 | 11:02 AM
kbracing96's Avatar
But with the bigger Turbine housing and wheel, he might have less then a 1:1 ration. I have a 5.7 with MP t76 and a 38mm gate in the same location as his. I have no problem holding 135KPA with the muffler on it. I pull the muffler, and it goes out to about 144kPa. Reason, less back pressure. You want to test to see if your WG is to small, just pull the spring out and go drive it. If it makes any boost and it keeps climbing, then you have to small of a waste gate, but I'm gonna put money on it won't make hardly any boost at all.
Old Mar 31, 2009 | 11:42 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by kbracing96
but with the bigger turbine housing and wheel, he might have less then a 1:1 ration. I have a 5.7 with mp t76 and a 38mm gate in the same location as his. I have no problem holding 135kpa with the muffler on it. I pull the muffler, and it goes out to about 144kpa. Reason, less back pressure. You want to test to see if your wg is to small, just pull the spring out and go drive it. If it makes any boost and it keeps climbing, then you have to small of a waste gate, but i'm gonna put money on it won't make hardly any boost at all.
Old Mar 31, 2009 | 11:50 AM
TURBHOE's Avatar
i think i'll try that. now that you mention it, this gate made 7psi on a honda accord. do you happen to have any 5psi springs laying around? i'll trade you a 7psi spring lol.
Old Mar 31, 2009 | 11:52 AM
TURBHOE's Avatar
for the record i'm not trying to say anything bad about the setup. i love it just want 10psi on low boost.
Old Mar 31, 2009 | 01:09 PM
TrickTurbo's Avatar
Truck Sponsor
I would give you a 5psi spring if I had one.
Old Mar 31, 2009 | 01:31 PM
TURBHOE's Avatar
that sucks. how bout it KB you have any 5psi springs laying around?
Old Mar 31, 2009 | 01:43 PM
TURBHOE's Avatar
also, how do you adjust a hobbs switch? my fuel pump comes on before boost comes on. i think it is set really low from sts. i have it on that little port on the turbo compressor. it screwed right in so thats where i put it. it was one less vacuum line to run.
Old Apr 1, 2009 | 04:04 PM
TURBHOE's Avatar
i found out the evolution gate is only a 35mm gate. i have a 38mm tial here i'm going to try. also found out that 1800 WE TURBO. is not sts's phone number
