boost comes on strong but as engine rev's up boost creeps to zero?
Old Aug 21, 2007 | 10:55 AM
  #21
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by Spires
NIce and dry out but problem still there.. Get this, even at low boost 5-6psi, the truck will run like raped ape to 6psi then drop down to about 2psi then take off again up to 6psi then drop and so forth... I cannot figure out what the hell is going on here.
Is it rpm related? Are you describing going through the gears?.
Old Aug 21, 2007 | 09:21 PM
  #22
Spires's Avatar
Ahhh I got it! Turned out I installed the boost control regulator improperly.. I had Rick from STS mail me the instructions as I lost the originals. I saw that the regulator goes off a tee from the boost reference line and regulates boost to the BACK of the wastegate, applying pressure on the back side of the diaphram. I simply had the regulator In-line on the boost reference line.
GrooveCityZ71
Aug 31, 2015 12:05 PM
fastjweb
Aug 15, 2015 10:47 AM
elpyro89
Jul 28, 2015 05:51 PM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
