Blowing out Spark...
Old Jun 2, 2009 | 03:42 PM
LowBlack99's Avatar
Originally Posted by 03tahoe22
stock valvetrain and internals.....
We have a winner! Get some stiffer springs.
Old Jun 2, 2009 | 05:09 PM
thunderwagen's Avatar
At that much boost you are probably floating the valves. I had the same problem and once I swapped the springs it was all good.
Old Jun 5, 2009 | 09:48 AM
03tahoe22's Avatar
The breaking up is all of third gear in the 1/4 mile.... I was told if it was valve float it would only be in the high about to shift rpm range. Going to gap the plugs this weekend and then test it....
Old Jun 5, 2009 | 11:04 AM
I promise you its your valve springs. The stock springs can't take that much boost and will float. Get some patriot golds or some 918's.
Old Jun 5, 2009 | 06:32 PM
code4's Avatar
9 Second Club
I had the same problem in 3rd @ 16#'s. I gapped my plugs down to .025 & raised my dwell time above 4000 rpm's to fix it. But since you are running stock springs it could be that.
turbo6c3
Oct 5, 2015 06:11 PM
01silvy
Sep 26, 2015 10:20 PM
TrickTurbo
Sep 23, 2015 08:41 PM
Velocity1
Sep 22, 2015 01:32 PM
Orlerr
Sep 21, 2015 08:32 PM
