Best Spark Plug for 5.3 with Supercharger?
Old 04-13-2016, 05:39 AM
  #21
03sierraslt's Avatar
Originally Posted by madmann26
Most people will tell you to not use a projected tip plug, ie, iridiums.
I use a TR6 gapped at around .027. They work great and are cheap and plentiful.
A TR6 Is a projected tip also, it's the plug design not the tip material that determine projected or non projected. A TR6 equivalent that is non projected is a BR6EF.
Old 04-13-2016, 03:01 PM
  #22
rocknZ71's Avatar
TR6's gapped at .032
Old 04-13-2016, 06:49 PM
  #23
1bad2k's Avatar
I have a set of those I am about to swap. What would you get them at for a mp112 on a LS6 making 6 or 7 PSI?
Old 04-13-2016, 08:13 PM
  #24
For that boost I would run them at .032 which should be what they are gapped at out of the box. Naturally I would check them.
Old 04-13-2016, 10:22 PM
  #25
1bad2k's Avatar
Thanks, yeah I'll def check them.
Old 04-13-2016, 11:48 PM
  #26
0235SS93's Avatar
Ditch the tr6s and run ngk r5671a-8
Old 04-14-2016, 04:40 AM
  #27
1bad2k's Avatar
Yeah I'm about to pull the TR6's and put in the BR6EF. I'll check those out that you mentioned.
Old 04-14-2016, 05:49 AM
  #28
Why run a non resistor plug in a LS? Many have had issues with this. Also a 8 heat range is too cold for his boost level.
Old 04-14-2016, 10:44 AM
  #29
Resident Retard
BlackGMC's Avatar
People always say that but i have never seen a post/thread/anything. Not doubting you but seems like 1 guy 10 years ago had an issue and that idea just kinda took hold.
Old 04-14-2016, 10:50 AM
  #30
Even say that's a non issue, a 8 heat range is way too cold for that.
Quick Reply: Best Spark Plug for 5.3 with Supercharger?
