Bad Gas Symptoms?
I must confess here, I am not savvy to tune talk. Please bare with me and my layman questions. You are answering a bit over my head. I am very grateful and hope you can get what I need to know into my thick skull.
You may be able to read between my lines and see I am trying to figure out if I am being jerked around or not.
I goto get my trans tweaked and end up with a detonating motor running richer than when I went in and told it's a relearn thing.
Please be frank with me guys. Is this total BS or not?
All I know is the pinging is lessening and My AFR's will not return to the low 11's @ WOT. I am totally lost as to why.
For all I know it could be the hotter weather?
It sounds to me like he lost your tune and put a stock one in, and then tried to make it rich enough to get rid of the knock. There is nothing in a tune that will make it richer when it detonates. The computer only backs off timing when it sees knock. I have payed with lowering the converter lockup rpm and got detonation, but not severe. I often get detonation within a couple of miles of being sold a tank of not 93 octane that was labled 93 octane.
the fuel has nothing to do with it. You need to get the tuning software yourself and quit getting jerked around. People spend thousands of dollars on mods yet have no clue what's going on with their truck. Tuning software should be one of the first things people buy.
do you still have the maf? it defiantly shouldn't run richer if it was just a trans tune. i agree sounds like he lost your tune and didn't wanna fess up. but if he was smart he would do like i do and just download it off the pcm again. using the beta hptuners i've had to do this a few times. the pcm will usually (unless modified) learn knock and not add the timing anymore. if it sees its pulling the same timing all the time it will "knock learn" and try to stop adding it. but its not the way you want to go. also the computer will pull timing when the intake air temp gets too hot so that you won't get KR caused by intake air temp rise. well it should anyway.
again all this is subject to the tune you have in your computer.
If the converter is locked at that point and didn't used to be, the engine might have always been prone to detonate at those rpm but wasn't knocking because the motor would rev a little higher before, or maybe downshift. Or if your tune is screwed up, anything is possible.
