Backpressure Testing With New Hot Pipes
Old Oct 15, 2012 | 11:30 PM
  #21
Llaverito's Avatar
I wonder how much a 3in id log would have helped on the t6 housing
Old Oct 15, 2012 | 11:41 PM
  #22
Atomic's Avatar
I have a gauge for that
Considering I basically doubled the area of the pipe going to the turbo, probably not a whole lot.
Allen, what size turbine were you using on what size engine?
Old Oct 16, 2012 | 07:24 AM
  #23
TrickTurbo's Avatar
Truck Sponsor
Nice info.
With the fab skills you could build a simple spool valve with manual controll to see if it helps your low end. Several vids on line were guys built their own. Using vacuum/boost controlling the valve.
Old Oct 16, 2012 | 12:19 PM
  #24
carbongmc's Avatar
Can I have sex with your welds? I'll be quick, promise....
Old Oct 16, 2012 | 01:48 PM
  #25
sand man's Avatar
Ill pay for your pleasure , 1 condetion though , they must be red hot
Old Oct 16, 2012 | 01:53 PM
  #26
JoeyGC5's Avatar
Nice upgrade and results. Are you still using the e-boost street controller also?
Old Oct 16, 2012 | 01:55 PM
  #27
Atomic's Avatar
Yep, still using the eboost street.
Old Oct 16, 2012 | 05:28 PM
  #28
Spoolin's Avatar
GFYS and STFU
Great R&D and write up Richard! dropping almost a point or 18psi in back pressure ratio is no small feat! Very interested in seeing where you go from here.
Nelson, did you mean Tubular manifold or Turbo manifold? Was curious as to if anyone's compared the back pressure ratio between a log style and that of a tubular style manifolds and also if maintaining the exhaust pulses via tuned pipes actually has a significant advantage over the log style.
Kinda funny that 5 years ago prior to Parish people where still debating whether log style manifolds could work!
There's two reasons why I bought CurtD's old parts. One, like Richard said Walker's welding is fantastic and two, he did a great job of actually engineering the system. There are alot of pipe diameters, pipe lengths, arrival and departure angle's of merging pipes and Y's that alot of times are overlooked. But Walker at MPfab did a great job making it all work and work well.
chopperloco
Sep 28, 2015 08:40 AM
TrickTurbo
Sep 23, 2015 08:41 PM
JordanH
Sep 12, 2015 12:02 AM
sTNT971
Sep 11, 2015 02:38 AM
LT-1 SS
Sep 3, 2015 10:24 AM
