Anyone Use 6.0L Heads on 4.8L to Lower the Compression Ratio?
Originally Posted by dug
I thought off idle torque is a non issue with screw superchargers. 25lbs is probably too much but lower compression is always gonna be safer.
thats my point, the more boost you run, the quicker it comes on. Also, you can get a higher stalled torque converter that allows higher rpms outta of the hole. Dont Ford Lightenings and cobras have 8.5 to 1 compression?
Lower compression *can* have a benefit if you are in boost more often than not, i.e. race car/truck. There is a tradeoff with low compression of non-boost response that can make a street vehicle less fun to drive. It is a give and take, just like camshaft selection.
Originally Posted by vanillagorilla
The stock 4.8 won't last long either pushing 25psi. If you're serious about high boost, then why worry about the SCR. At the boost levels you're talking race gas will be a necessity no matter what SCR you have.
yeah, but still made 630rwhp
Our built up 8.5-1 comp. 4.8 made a whopping 200rwhp NA and 630hp with a Turbo. Off boost it sucked ,bad.
