Anyone with a Procharger F series blower...
Just pick up a New F1X and was told I can't run it with my 8 ribs pulley setup, which is brand new stage 2 crank pulley system .. Have any of you tried it??
I know I have to run at least a 4" pulley..
Can it be done, yes. Will you have headaches trying to make it work, probably. It’s not an optimal setup, you’ll have to spin the blower rather slow to keep it from slipping or snapping belts, which in turn takes it out of its efficiency range. |
Originally Posted by blown02408
(Post 5450876)
Originally Posted by Flewbyu123
(Post 5450891)
Hmmm ok.. I know I will change it later to a cog or 12 rib just have not found what will fit my 2003 Silverado not much is listed for it.. Thanks, for your input!
Here what I found https://cimg6.ibsrv.net/gimg/www.per...73b1a9ff97.jpg Hmmm https://cimg5.ibsrv.net/gimg/www.per...da9d08d3a1.jpg 28psi |
Pretty sure you can upgrade the stage 2 bracket to 12 rib if necessary. I’ll be selling one of my own 12 rib brackets soon, however it’s being sold in kit form with an F1C, that won’t help you any though. |
My newest creation, ignore the fact that there is a standard rotation procharger in that picture, the new one is reverse. https://cimg5.ibsrv.net/gimg/www.per...be23440ad.jpeg |
