Anyone make their own manual boost controller?
Old Aug 13, 2009 | 06:40 PM
MGMC's Avatar
12 Second Club
Default Anyone make their own manual boost controller?
Just seeing if anyone has made their own manual boost controller? i hear its simple
Old Aug 13, 2009 | 08:25 PM
schino's Avatar
i did on my car. used a pipe elbow. drilled and tapped a hole concentric to one of the holes out the back side. got barb fittings and seated a ball bearing into the back side of that. threaded in a screw with a spring on the end putting pressure on the ball seating on the barb fitting.. make sense? lol
Old Aug 13, 2009 | 09:34 PM
quicksilverado's Avatar
You can get them on ebay for 5-6 bucks. Thats what I have on mine.
Old Aug 13, 2009 | 10:10 PM
MGMC's Avatar
12 Second Club
link? pm me if ya want
Old Aug 13, 2009 | 11:24 PM
Rick_Vor's Avatar
Not worth the gas and time to make your own.
http://cgi.ebay.com/ebaymotors/ECLIP...Q5fAccessories
But if your realy into craftsmanship...
http://www.geocities.com/chmwatson/FAQs/mbc.html
Rick
Old Aug 14, 2009 | 10:12 AM
LsxCody's Avatar
How would that be installed
Old Aug 14, 2009 | 10:40 AM
hellbents10's Avatar
LS1Tech Sponsor
Nothing works as good as a low pressure regulator. I run man. press. to the bottom of the gate and reg. press. to the top side to increase boost.
Old Aug 14, 2009 | 03:17 PM
1BADAZZSS's Avatar
Here is the one I run. Regulator just like on a air compressor.
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
Old Aug 14, 2009 | 05:38 PM
Mort's Avatar
That is identical to the manual one that STS sells. I have one with a solenoid to switch it from low to hi from the cab. Cost $50.
Old Aug 15, 2009 | 12:39 AM
Rick_Vor's Avatar
LOL! I have no idea! I meant to post this homemade style and I guess I copied the wrong link. This is the one I meant to post
http://cgi.ebay.com/ebaymotors/NXS-M...=p4506.c0.m245
1BADAZZSS Here is the one I run. Regulator just like on a air compressor.
I agree. The turbonetics style seems lke the best style of the manual controllers. I picked up a used Blitz electronic Dual Boost controller and couldn't be happier. Super easy to set up and adjust the max boost pressure + it allows you to have a DD boost level and a race level at a flip of a switch.
Rick
