anyone have a stock magnuson tune for a 2003 5.3?
Old Oct 27, 2015 | 08:16 AM
BigKID's Avatar
Originally Posted by Mr_Safety
thanks for the response. timing was 16 degrees, map was steady at 103 calculated airflow drops. I will try to get the tune and log loaded up tonight.
I would look more in to this (bold in quote). If map is steady and the calculated airflow drops, I suspect there is hole in a MAF table or the MAF itself is bad. You could also check all the plumbing behind the MAF to make sure there are no leaks. Are you injecting anything pre-maf such as meth or nitrous?
Old Oct 27, 2015 | 11:24 AM
Mr_Safety's Avatar
Not running meth or nitrous. I have another maf that I am going to put on to see if it will fix it but it has been work fine up till now so I bet there is a issue in the maf tune.
Old Oct 28, 2015 | 06:46 PM
Mr_Safety's Avatar
well took the tune from the 2005 and copy and pasted it to my tune and did a write intire instead of a calibration only. It fixed the problem for the most part. I still had to put a maf tune from my buddys 03 ss silverado with a mp112. It was still a little lean but was not just suddenly droping like before. After i did the maf tune it is almost perfect just needs a little fine tuning. Thanks for all the responses and help.
Old Oct 28, 2015 | 10:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you have to scale the injectors for the Return style fuel system?
I believe that's one of the small differences.
Old Oct 28, 2015 | 11:09 PM
Mr_Safety's Avatar
My friend wrote the tune for me and he said he didn't have to touch it for some reason it wasn't set for return less but it did have 37# injectors. He just left those values in there for now and overall it was looking pretty good. Around 11.5 on the wide band with zero knock. So with a little bit more fine tuning it should be good to go.
Old Oct 28, 2015 | 11:14 PM
Mr_Safety's Avatar
I was wrong it was 39# injector values
Old Oct 28, 2015 | 11:28 PM
1FastBrick's Avatar
I think... If I remember correctly...
On the 99-03 Return style, the value is constant as the vacuum regulates the pressure.
On The 04-up return Less style the value increase as the MAP value increases or something like that since the fuel pressure remains the same.
Old Oct 29, 2015 | 07:42 AM
Mr_Safety's Avatar
ya your right i meant to say it was set for return style. It was set to 39# across the whole table instead of increasing.
chopperloco
Sep 18, 2015 06:44 PM
rednekferlife101
Sep 14, 2015 05:27 PM
InsaneDomestics
Sep 10, 2015 05:32 AM
InsaneDomestics
Sep 7, 2015 09:19 PM
slowswb
Sep 5, 2015 02:27 PM
