anyone have a stock magnuson tune for a 2003 5.3?
Old Oct 25, 2015 | 07:45 PM
Mr_Safety's Avatar
Default anyone have a stock mp112 magnuson tune for a 2003 5.3?
I just installed my used maggie and I am having trouble getting the tune correct. I am using hp tuners. I am going lean under medium throttle. i just installed a new racetronics fuel pump and hotwire kit also have a fuel pressure gauge installed so i know the fueling is not a issue. We went through the maf and ve tuning procedure by the book. under boost i start off fine and then all of a sudden jumps from around 11- 12 up to 14-15 on the wide band. I would like to have the tune that comes with the supercharger to have a better starting point. Or if somebody would like to take a look at my tune and a log i can email it. thanks.
Old Oct 26, 2015 | 02:50 PM
Mr_Safety's Avatar
Bump. Also it's a mp112
Old Oct 26, 2015 | 04:24 PM
BigKID's Avatar
I'm assuming you are still running the stock operating system (1bar, maf, closed loop)? How did the timing look where it went lean? How about calculated airflow? Map reference?
For a Magnuson file to compare, I am sure you could fine one in the HPT tune repository... https://www.hptuners.com/customers/tune.php You will have to be logged into HPT site to use it.
camarokid6771's Avatar
here is one I have for a 05 im not sure if its a stock magnacharger file but its atleast something to compare yours to
05 5.3l magnacharger maf.hpt
Old Oct 26, 2015 | 05:47 PM
Mr_Safety's Avatar
thanks for the response. timing was 16 degrees, map was steady at 103 calculated airflow drops. I will try to get the tune and log loaded up tonight.
Old Oct 26, 2015 | 05:51 PM
Mr_Safety's Avatar
Attachment 75559
thanks i am going to compare it to mine.
Old Oct 26, 2015 | 09:20 PM
Mr_Safety's Avatar
here is a log I did on hp tunners if anyone cares to take a look at it.
ryans gmc lean problem.hpl
Old Oct 26, 2015 | 10:20 PM
Gadgetized's Avatar
What injectors are you using? Are you running the stock style fuel system? Return system vs returnless. What fuel pressure are you seeing on decel?
Old Oct 26, 2015 | 10:37 PM
1FastBrick's Avatar
Custm2500's Rude Friend
MP112 and TVS1900 use the same tune.
The tune should be fairly close for 2003-2005 The 06-07 Classic had some things changed in the OS Like the pedal, TAC module and TB.
EDIT: 03 is a return style and you will need the correct info in the fuel tables for that.
Old Oct 27, 2015 | 07:58 AM
Mr_Safety's Avatar
I'm using the 42# injectors that come with the supercharger kit. Upgraded the fuel pump to the racetronics with a hot wire kit. It is a return style system and it uses the stock vacuum reference regulator from the stock fuel rails. I have a fuel pressure gauge in the cab but I haven't paid much attention to it on deceleration I can check on that though.
