Any blown street trucks running 10's w/o Nitrous?
Old Aug 14, 2012 | 09:28 PM
  #31
stock48's Avatar
9 Second Truck Club
Id say for decent power the turbo is cheaper once you figure in the headers, trick exh, and 8 rib drives to make the blower spit out 10 sec power. Also with traction limited 2wd excab the extra mph from a turbo will help the times more than traction wasting the low end of the blower away...
Old Aug 14, 2012 | 10:11 PM
  #32
fastnblu's Avatar
Originally Posted by ZO6Ted
Ok then it CAN be done. Starting with my long block and an 80e then, what would be the MOST cost effective? If I could run 10s with a 2300 or 2900 I would love it but I think after exhaust, and supporting mods, is a front mount turbo less expensive? Loved my rear mount 5.3 but I want to go faster. It is a street truck DD not a race truck and must be reliable as well. Yeah I know, fast + reliable = $$$
U think like I do, a reliable, fast DD. You're just goin more extreme than I will.
Turbo is definitely cheaper, just depends on how you want the power delivered.
To the ground.
Since I've been away from PT for awhile, until the last month, I see somebody shot past the 10's & into the 9's!!!
So do u have the fastest on PT? U gotta be way up there.
Granted I just put on Radix, & not that I don't approve of its power, cause I do, but if I build another vehicle, or ever do FI again, it'll be turbo.8-
Greater ceiling of power, cause a person is more likely to run outta motor or driveline b4 runnin outta turbo. Plus, I have a few other reasons.
To me, a 4.8 Turbo w/. a 4L80E is a sweet combo of power & economy if I stay outta it I'd think, but don't want anything other than a stock stall so that leads me to think a 4.8T w/ 6spd. M is close to perfect. Anyone running somethin close to that on here? By chance, are they in low 11's, or 10's?
But I know Ted is goin for more killer than my idea.
Old Aug 14, 2012 | 10:19 PM
  #33
stock48's Avatar
9 Second Truck Club
No there are a cpl low 9 sec, and 8 sec trucks on here. Mine might be the quickest factory short block, or single power adder 4x4 tho not sure. Foose is knocking on the door of 9's with his 4.8L as well..
Old Aug 14, 2012 | 10:23 PM
  #34
fastnblu's Avatar
Who has the fastest 4.8 single turbo on here, running a 6M too?
What kinda times?
Nothin over a 4.10 gear, anyone?
Old Aug 14, 2012 | 10:28 PM
  #35
stock48's Avatar
9 Second Truck Club
My boost only single turbo 76mm, 6.0L has been 9.73/139mph and a best of 140.8mph, on a factory short block. Not sure about a 4.8L M6.
Old Aug 14, 2012 | 10:36 PM
  #36
fastnblu's Avatar
stock48, what rear gear & what are u guys running for a rearend to survive 10's & lower?
Old Aug 14, 2012 | 10:39 PM
  #37
stock48's Avatar
9 Second Truck Club
3.73 here.
Old Aug 14, 2012 | 10:45 PM
  #38
NORTH TEXAS TBSS's Avatar
formerly NORTH TEXAS TBSS, then slowgibbs, and now back to NORTH TEXAS TBSS :) (2012-05-27)
My TBSS has been 10.49 @ 129 with meth only.
Old Aug 14, 2012 | 10:46 PM
  #39
kbracing96's Avatar
The hardest problem with making big power with a PD blower is the blowers are so horribly inefficient! Ya, they make instant power, but according to KB's blower dyno, their 2.8l blower consumes about 150hp to pump 15psi of boost! Turbo's and centrifugal are WAY less then that, so your not having to make so much power that's not even get to the back of the crankshaft.
Old Aug 14, 2012 | 11:53 PM
  #40
Blown06's Avatar
8 Second Truck Club
Originally Posted by pewterliftedz
He sure was spinning the *** out of that D1 lol... What were you at blown? Like 23 or something like that right.
Yea, it showed 23 psi on the data log.
But that was to run the 10.40's. It actually went 10.90's on 14 psi with an out of the box procharger kit, including the stock pulley, stock tensioner etc.
The arguement that a turbo kit is cheaper than that, I might have to argue with. The turbo route certainly is not as friendly.
