Another Turbo cam thread...
Old Feb 21, 2012 | 07:04 PM
evand's Avatar
I think at this point. I would just pay for a recommendation.
Old Feb 21, 2012 | 07:11 PM
BlackGMC's Avatar
Resident Retard
I'd say its pretty hard to deny the results that stock48 is getting out of his straight small designs.
Agreed and i believe his cams are cheaper than anyone elses.
Old Feb 21, 2012 | 07:49 PM
2007chevy5.3l's Avatar
Originally Posted by f4tal
ECSB LQ4/stock 317s, NNBS intake, 42lbrs, 224/228 .600ish lift on a 110+4lsa
80e stock converter and 3.42s
Sooo, when did you get a ECSB??
Old Feb 21, 2012 | 07:53 PM
kazfan30's Avatar
I truthfully don't think you can make a "wrong" decision .. seen 5.3's for example with anywhere from 212 cams all the way to 220's.. and they all make similar power and run similar times.. even stock48 will tell you that his famous triple 12 cam will only be within a few hp from other cams... keep the cam in the 112 or higher lsa and descent lift and you won't go wrong. All do respect to stock48 and Isky cams... but guys you "can" still go fast with other cams... lol.
Old Feb 21, 2012 | 09:03 PM
bmd_CL's Avatar
^^^this guy has a point, honestly the truck is gonna make a **** ton of power no matter what with any cam...i would go with like a 222/224 .580/.590 114 tho lol
Old Feb 21, 2012 | 09:40 PM
f4tal's Avatar
IMO, your not trying to get the max out of your turbo setup, so no real need to have a great turbo cam. ANY cam will "work" it a turbo. Just put the cam in it that will give you that sound you want and then set the boost for the power you want and have the best of both worlds for YOU!
That's a quote from Kyle at KBracing in an older thread.
I know my 110lsa isn't a good choice and I don't mind changing the cam. I was just curious as to why you use the cams you use.
Old Feb 21, 2012 | 09:42 PM
f4tal's Avatar
I will NEVER pay for a cam recommendation. I've seen too many people get spec'd the same cam for completely different setups. Plus with as much research and knowledge that the guys on this forum have there is never any reason for me to throw $25 dollars away for a cam spec. Just my $.02
Old Feb 21, 2012 | 09:44 PM
BlackGMC's Avatar
Resident Retard
I will NEVER pay for a cam recommendation. I've seen too many people get spec'd the same cam for completely different setups. Plus with as much research and knowledge that the guys on this forum have there is never any reason for my to throw $25 dollars away for a cam spec. Just my $.02
You tell the Mr. Flat Bill!!!!
Old Feb 21, 2012 | 11:05 PM
02'Z71ONDUBZ''s Avatar
How do you plan to use the truck?
Old Feb 22, 2012 | 12:04 AM
stock48's Avatar
9 Second Truck Club
This is true as far as pk numbers go but the way the truck acts out of boost and works at the track is a whole different story... Dyno numbers are for
