Alum. blocks for boost
Old May 5, 2011 | 09:01 AM
  #21
OnyxSilveradoSS's Avatar
I'll try again
They make slugs for the stock LQ9/LS2 rods that are forged, rod could stay stock to save a few bucks, LS2 block, and a forged crank.
Not trying to change directions but I was reading on one forum that guys are using the smaller cranking in block like you have, going the other direction with the 4.8 crank...forget the site
SO how much time do you need to get ready for your last pre-radix shake down?? We need to find a rental...and try to put it on at the track, then we could see some real good compairsons
Old May 5, 2011 | 11:54 AM
  #22
loloone's Avatar
LS1Tech Editor
Fastnblu-
It's funny, you're on the same school of thought as I am. For a nice DD I'm content with the Radix but would like to maximize the thing and just leave it. I'll be happy with high 400s at the wheels.
With that said, if I'm going to reliabily crank up the boost I should probably do something about my 110K motor so if I'm going to crack into something why not make it an aluminum block and offset the weight of the blower?
I'm torn between an L33, or for a little more for the motor, but the same or less for internals I can step up to an LS1...or for a few bucks more an LS2. Hmmm
At this point though, since my Radix is still in the out-of-the-box status I've started saving my pennies and collecting parts. Going to do e-fans and the 90mm J-tube/LS3 TB, 100mm MAF or SD tune and build a 4" intake. Since I'm in Ca. I'm going to get some mids or shorty headers and open the exhaust. Then a good tune and see how it is. At that point I may forgo the GT2-3 and smaller pulleys until I can build a nice little motor. I wonder what I'll see with just the intake and exhaust sides/90mm setup for power?
Old May 5, 2011 | 10:14 PM
  #23
fastnblu's Avatar
Originally Posted by indigo s10
L33 is the code for the aluminum flat top piston 325 cube 5.3. Came in 05-06 ext, and crew cab 4x4's and Z71's.
Now we're gettin somewhere.
Originally Posted by OnyxSilveradoSS
I'll try again
Not trying to change directions but I was reading on one forum that guys are using the smaller crank in block like you have, going the other direction with the 4.8 crank...forget the site
Joe, why use the smaller crank like a 4.8 crank in a 5.3? Is that like how guys would do a 302 Chevy to wind it to the moon or like a 400ci brought down to a 377?
I don't need much time to get to track, just a few days notice. However, I just need the time in general, it's been a precious commodity for me lately. But I gotta make $.
You've lost your mind. I sure ain't doin a Radix swap @ track.
loloone, I'll get back w/. ya tomorrow on what I've found. I'll throw up some links & so on.
Old May 5, 2011 | 10:20 PM
  #24
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You will never feel a difference even if it is a 100# difference. Can you tell a difference in the handling of your truck between a full tank and an empty tank of gas? Thats 150#s right there. I personally cant tell the difference.
Old May 6, 2011 | 12:13 AM
  #25
TrailLaser's Avatar
^^ 100-lbs = about a .100 in the 1/4.. Comes in handy when you're chasing weight reduction later..
PS- I dont like rust, weight, or heat... Aluminum solves that too.. Just say'n..
_
Old May 6, 2011 | 12:25 AM
  #26
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you're hell-bent on it, skip over the L33 and the LS1, go straight to the LS2. If you're gonna spend the cash, get some displacement at the same time.
Personally, I say use the LM7 you already have. It's already paid for! "Run whatcha brung!!"
Old May 6, 2011 | 12:49 AM
  #27
TrailLaser's Avatar
^^ Hey AKz71, what did your truck dyno with cam and without blower..? (Also noticed those 1.8 rockers, @ ~ .583 lift)
Had the same cam in factory TBSS LS2 (non-s/c) made 383/383 on g-force dyno..
Old May 6, 2011 | 12:51 AM
  #28
It's never been on a dyno.
That will change on June 4th, if the transmission lives. I have a date with Alaska Raceway Park on May 21st.
How did you like the cam in your LS2?
Old May 6, 2011 | 12:58 AM
  #29
TrailLaser's Avatar
^^ Not bad (for n/a too), just a little weak on the top-end for the LS2..
Old May 6, 2011 | 01:54 AM
  #30
TIM Z's Avatar
11 sec. Truck Mod
To cut weight off the truck, cut the frame rails, def do away with the front brakes
LMAO ! HUBRIS !!!
Hey Tom, is the Radix on yet?
Seriously, once it is installed you will forget all about this thread for real. You wont be able to keep rear tires on as is with all the goodies you have.
