alternator problems with p1sc
Has anyone had problem with there alternator making noise after getting on the fas. Mines making noise and its new cuz its only been two weeks that I changed it. Anyone have any answers let me know
There is an issue with the procharger brackets the way they come from procharger on the 99+ kits. You'll notice that there are two bushings (one for each bolt) in the alt. bracket, that when tightened (without the procharger bracket) push on the alternator to squeeze it tight inside the bracket. The standoffs (bolt spacers) that come with the kit that are used on the alt bolts have a counter bore in them that are meant to clear the shoulder on the bushing in the alt bracket. The problem with this is that now the alternator really has nothing to squeeze it tight in the bracket and with the procharger kit installed is now "floating" the alternator. Much like how a brake caliper floats in the bracket.
This can and does create all types of problems including but not limited to belt slip, improper belt alignment, broken alt brackets, worn out alt bearings, broken alt bodies......
The fix is to measure the correct standoff between the bracket and the bushing to get the alternator to tighten back up in the bracket. Then machine the standoff or bolt spacer to that length and don't counter bore it. Let it push against the bushing.
Not sure if your problem is related to this, but every procharger truck I've seen with stock style brackets on it, you can reach over grab the alternator and it rocks back and forth.
hell yeah we did fix the problem. Got some thin washers to fit behind the alternator to space it out closer to the bushings in front of the alternator bracket. and its fixed now
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
