Afr ??
Old Jun 14, 2006 | 05:27 PM
blue 01's Avatar
Default Afr ??
The STS is going on this weekend but I have my XD-1 wide band hooked up for the last two weeks. When I am cruising at a constant 55 or 60 mph and let off the gas my AF goes up from 14.6, 14.9 to 15, 18, 32 for 1/2 second ,then 20 (flashing which = alarm) and the percent light comes on. 20 is the alarm on the gauge just for now. When the truck gets down to 45mph you feel a hesitation which I think is the converter unlocking and the AF go back to 14.6 , 14.9. I think it is do to the converter putting a negative load on the motor when it is locked.
Any thoughts? Dose any one else do the same thing?
Old Jun 14, 2006 | 05:42 PM
jephs422's Avatar
when you let off the gas, the motor basically turns into an air pump, that sounds normal to me, I guess.
Old Jun 14, 2006 | 06:29 PM
camcojb's Avatar
Most late-model vehicles shut the injectors off on decel, so that sounds completely normal to me.
Jody
Old Jun 14, 2006 | 06:50 PM
TIM Z's Avatar
11 sec. Truck Mod
mine does the same thing Darren, dont worry, its fun but also scary at times watching and learning these gauges and how a system affects them.
Old Jun 14, 2006 | 06:59 PM
thunder550's Avatar
High on diesel fumes
It's called DFCO, deceleration fuel cut-off. You can program it out in the tune if you want, but it's supposed to do that as a fuel saver.
Old Jun 14, 2006 | 10:49 PM
blue 01's Avatar
Good to hear. Thanks everyone.
Isak81
Aug 29, 2015 01:44 PM
mz00516
Aug 23, 2015 12:19 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
