adjust fuel pressure
Old Dec 15, 2006 | 02:46 PM
JOHN1L40's Avatar
Default adjust fuel pressure
Is there a way to up the pressure on a stock GM regulator? I seem to be a little low. I see 42 psi at idle and 58is at WOT. The manual says I should be between 55 and 62. I may go get a new regulator but it seems to work fine just a little low on the pressure.
Old Dec 15, 2006 | 02:56 PM
thunder550's Avatar
High on diesel fumes
Sounds about right actually. 58 psi at WOT anyway, I dunno where idle is supposed to be, but I wouldn't worry about it. That's for a stock fuel system anyway.
Did your STS kit come with a boost-a-pump or auxiliary pump or any fuel system modifications?
KySilverado's Avatar
If you look real close at the FPR there is an adjusmtend screw in the middle of it. Requires a specialty tool to adjust it.
Old Dec 15, 2006 | 03:00 PM
thunder550's Avatar
Hmm....you learn something new everyday
Old Dec 16, 2006 | 10:01 AM
Stoichiometric's Avatar
I unplugged the vac. line on the FPR to see if it made any difference on my lean issue. It didn't change that at all, but it may give you a full 58psi at idle.
Old Dec 16, 2006 | 12:31 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I bought a new one recently and it didnt have the screw. I hink the original did. It was a star pattern tool I think. I sit at 42-44 at idle as well and 60 at wot.
Old Dec 16, 2006 | 07:26 PM
The 2 I have handy are just like this. Star/torx type screw with a little nub in the center.
Old Dec 16, 2006 | 09:16 PM
JOHN1L40's Avatar
Well just FYI I went and picked up a new FPR and the pressure at idle jumped to 46 psi and went to 62 psi pretty fast under load. I think my old one was just getting lazy. Better to be safe. The psi at idle with the vacuum line disconnected was 58 psi.
Old Dec 16, 2006 | 09:19 PM
1SlowHoe's Avatar
Does it have the adjustment screw? When I replaced mine I didnt get any increase. I replaced the fuel filter at the same time. Maybe 42psi is all I get. Glad yours worked out.
Old Dec 16, 2006 | 09:28 PM
JOHN1L40's Avatar
No adjust screw. I replace my fuel filter every oil change. I figure cheap insurance and its only a 5 min job.
