99 Z71 turbo build list reviews needed
Old 11-24-2016, 01:54 PM
Registered User
Snooze's Avatar
Default 99 Z71 turbo build list reviews needed
Need some reviews on my build list for the turbo build on my 99 z71 stepside truck to make sure I'm not making any mistakes or missing anything when ordering stuff. Truck is a 5.3 4L60e combo now with push button 4x4, looking for 500-600 horse through an 80e. I have E85 locally but would like to be able to run pump still, not sure if I will have enough pump with the 450 or if maybe I should just stay pump with meth. Critique away and let me know what you think.
Fuel:
Walbro 450 F90000274 fuel pump
Kenne bell 40a boost-a-pump
FIC 1000cc injectors
Aeromotive A1000 13101 FPR
-8 feed and -6 return
Flex fuel sensor
Turbo:
VS racing or ON3 billet 7875
Trick performance T4 manifold
Custom 4 inch down pipe
Treadstone intercooler
JGS 400R wastegate
JGS 500 BOV
Turbosmart eboost2 controller
Exhaust:
Custom 4" dumped before axle
Carven R series muffler
Trans:
4L80E swap
HD2 shift kit
Trans brake of some sort? Sloppy style?
Jakes stage 2 rebuild
TruCool 40k cooler
Transfer Case:
Merchant auto pump rub kit
Engine:
SBE 99 5.3 regapped rings
Stock heads maybe slight hand port
Tick stage 1 turbo cam
LS9 gaskets
Misc:
Braided hose for fuel, oil, trans fluid and other
4 vibrant HD 3" clamps 12516
Window tint 35%
Rear end:
10 bolt
3:73 gears
Detroit tru track
Rims & Tires:
20" GM all terrain style rims OEM or reps
33-12.50-20 ridge grapplers
BORA 2" spacers
Suspension:
4" lift Deaver F87 leafs with factory block removed (fox or bilstein 5100 shocks)
Traction bars?
Atomic coilover brackets
QA1 promastar double adjustable coilovers
Rough country UCAs
Leveled up front to match the back
Steering:
PPE tie rod sleeves
Cognito pitman and idler arm support
Body:
New rockers, cab corners, paint and repair
Z71 Tahoe valance color matched as well as bumper cover
HD or original grille color matched with billet bow tie and inserts
Color matched rear bumper step pad
Debadge and demold
Lighting:
Opt7 LED heads, tails, and fogs
Switchback Markers eliminate DRL
Candied tails
Cleared heads
Interior:
Alpine head unit (CarPlay?)
Focal or infinity 6.75" component fronts and 4" component rears
12" focal or infinity sub in sealed box
Zapco 650.6 amp
Escalade cluster
As many Denali or escalade trim pieces as I can find
PCM/Tuning:
02 computer
02 flex fuel Tahoe 2 bar OS
Segment swap for the 80e
Tuned with HPTuners (by me depending on how well I do fine tuning might be done by professional this is my first time trying)
Old 11-24-2016, 02:51 PM
FFDP's Avatar
Don't forget a 2 bar MAP sensor and a seperate IAT sensor because you won't be using the MAF anymore.
Old 11-25-2016, 03:07 PM
Registered User
Snooze's Avatar
The cobalt MAP will work right? And a GTP IAT sensor?
Old 11-25-2016, 04:59 PM
FFDP's Avatar
Yeah, the colbalt MAP will be just fine. The IAT comes on tons of different GM cars, that one will just work fine. Even one from a camaro or similar would work too. Might even be the same part numbers.
Old 11-25-2016, 08:25 PM
Registered User
Snooze's Avatar
Alright thanks
Old 11-26-2016, 07:25 AM
You won't need a transbrake. Also go ahead and get gadgetizeds 2.5 bar map from the get go.
Old 11-26-2016, 07:37 AM
Registered User
Snooze's Avatar
The trans brake I was thinking for sand drags, do you think it will spool fast enough on the foot brake? If I go 2.5 bar MAP the flex fuel is out the window as the Tahoe FF OS is only supported up to 2 bar, will pump and meth be enough? That would save on a pump.
Old 11-26-2016, 08:58 AM
You can build all the boost you'll ever need in 4wd on the footbrake. I'd look into swapping it over to hydro boost brakes. I'm currently running 18psi...93 octane -20 ww fluid with a snow meth kit. Truck ran a 7.2 1/8th and an 11.6 letting out after the 1/8th.
Old 11-26-2016, 09:09 AM
You'll max out the 2 bar map long before your fuel system will be in a strain. I'm running a single walbro 400..stock lines with a flex fuel fuel rail. I'm probably close to maxing this fuel system out.
Old 11-27-2016, 12:36 PM
Registered User
Snooze's Avatar
Even with stock rails and possibly E85?
