99-06 intercooler reservoirs .
Truck Sponsor
We offer reservoirs for
99-06 GM trucks
07+ GM trcks
Ford Lightnings
Universal battery tray (large tank 2 gallons)
And soon a small
Universal battery
Here's a couple of quick pics, I took with the phone. Drops right in bolts up and no need to loose the fender support. Tank hold 1.5 gallons, 3.5" easy on off vented lid.
Really easy to add ICE and help keep air temps low.
Black composite material, is compatible with fuel and water meth.
99-06 GM trucks
07+ GM trcks
Ford Lightnings
And soon a small
Universal battery
Truck Sponsor
There are 3 ports all -10an female thread.
Tank comes with two fittings and one plug.
Port location are all on the engine side of the tank
Front lower corner. Rear lower corner. Both of these are below the ac line.
Then one mid upper port. This one is above the ac line.
I will get some better pics up.
Truck Sponsor
Hose routing is left up to then end user. The fittings comes out of the tank are -10 an.
We offer the Push lock hose ends if needed.
I would feed the pump with the lower rear fitting. The other two forward ports I would use for the return.
Get y'all a better install pic this week.
Rick
Rick
