90 mm throttle body question?
Old Dec 21, 2008 | 01:42 AM
ryan_prettyman's Avatar
Banned
Exclamation 90 mm throttle body question?
I have a 2006 flexfuel 5.3 truck I was considering putting the trailblazer ss throttle body on it I have done some research the plug on it should be exact same as my electric TB, it should work without the wirring harness that you guys are always talking about, I know the car TB is totally different but the truck 90 should work like a champ what's the issue!
Old Dec 21, 2008 | 02:00 AM
Banned
87mm!
Old Dec 21, 2008 | 09:34 AM
Truckshop's Avatar
it wont bolt to your intake nor will it plug in to your harness.
Old Dec 21, 2008 | 09:40 AM
Banned
Its the sme plug as mine if I had one I would temp install it and cycle the accelerator through just pluged in that is!
Old Dec 21, 2008 | 09:42 AM
Truckshop's Avatar
you should really look at the connectors again.
Old Dec 21, 2008 | 09:44 AM
Truckshop's Avatar
http://www.motoralldata.com/alldata/...7018/122188682
your connector
http://www.motoralldata.com/alldata/...7018/122188684
tbss connector.
Old Dec 21, 2008 | 11:26 AM
BlownChevy's Avatar
blownerator
25 Year Member
I am pretty sure you will need the X-Link to make it happen. And if you are planning any FI, I would go RIGHT to the LS2/LS7 TB. The TBSS TB tends to have failure issues at high boost levels.
jdb11386
Dec 3, 2015 09:34 PM
TimDave217
Aug 24, 2015 04:38 PM
Slammed96
Jul 27, 2015 07:22 AM
GreyChevy
Jul 7, 2015 08:57 PM
Gadgetized
Jul 7, 2015 04:40 PM
